Home > Technical (L405) > Idiosyncrasy - Larger Oil filter for TDV6 than SDV8?
Gremlin500
Some time ago, I ordered a Mahle oil filter for my 3.0 TDV6 L405 from Amazon, only recently to find it was the wrong one OX 153/7D2 i.e. suitable only for SDV8 4.4 V8 engine Embarassed
So, I ordered the correct part this time and when it arrived, was surprised to see the V6 filter OX 776D is taller and also of greater diameter than the MAHLE SDV8 filter.
You would think the V8 engine with greater oil capacity and more cylinders, would have say a 20% larger filter than the V6 but in fact it seems to be the other way around?
Any ideas as to why this should be so, and have I really got my facts right? Sniggering Question “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #661334 7th Apr 2023 11:19pm
caymanblack
Surprised to hear this Gremlin, I agree you would think it would be the other way around! overfinch modified
Post #661341 8th Apr 2023 10:12am
knwatkins
Yes, that's right Gremlin and something I've thought about previously.
Similarly, by comparison to both the 3.0 and 4.4 JLR/Ford engines my wife's 2.0 BMW filter is huge. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #661350 8th Apr 2023 2:14pm
cass
United Kingdom 2014 Range Rover Autobiography SDV8 Causeway Grey
Has it always been bigger? were the earlier TDV6 engines fitted with a smaller filter that was later quietly upgraded by JLR in an effort to reduce the number of crank failures?
Purely speculation on my part - I have NO evidence to suggest this is the case.
Post #661357 8th Apr 2023 4:03pm
knwatkins
No. It's always been the same on the 3.0 since the engine came out in 2009. There was a change in the filter and associated housing design when the 2.7 was partially re-designed to form the 3.0. Kev
Post #661362 8th Apr 2023 4:37pm
Vogue
The larger filter is needed to absorb the bits of crankshaft, bearings and rings 😂➡️ 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #661365 8th Apr 2023 6:19pm
Rolling with laughter
Post #661367 8th Apr 2023 6:50pm
cass
Nonsense - It's all a myth, there is no problem with the crankshafts apparently
Post #661370 8th Apr 2023 7:01pm
Gremlin500
Evil or Very Mad Razz “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #661372 8th Apr 2023 7:14pm
Whistle Whistle Whistle Sniggering Thud Laughing
Post #661386 8th Apr 2023 11:17pm
Gremlin500
Off Topic
This is a discussion about Oil Filters, not crankshafts?
The implications for SDV8 engines with less than significant oil filters may or may not be important!
Indeed are either filters adequate?
Perhaps they are, given my 16000=4000 mile service intervals! “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #661387 8th Apr 2023 11:45pm
Merchy
From my basic understanding, the 6 engine was designed for smaller engine bays and even transverse fitting, it has a smaller number of main bearings for the crank shaft than the 8 engine.
The main journals on the 6 engine are not as wide as those on the 8, thus the 6 engine main bearings and bearing caps are under greater load for a given area, heat transmission is also a factor from a smaller surface area, hence the need for a higher oil pressure and/or greater oil flow, thus a larger oil filter element.
Not exactly a detailed answer but just trying to cover the basics, obviously there are other factors.
As a marine engineer, I did start researching crankshafts / design / materials / oils......that was a crankshaft internet rabbit hole I fell down that cost me a few hours of my life which I won't get back Thud I would advise other members not to do the same, I even ended up reading up on harmonics relative to crankshafts, and harmonics is a complete bloody science in itself, then you get to finite analysis Censored Another science. It's far easier to be a luddite. Very Happy
Post #661391 9th Apr 2023 4:19am
cass
So it seems that my comment about being crank related wasn't far away.
It could only be JLR - picture the meeting "Chaps it seems our new engine is a bit fragile we should develop it a bit more. No stick a bigger oil filter in and keep our fingers crossed" Rolling Eyes
Sadly I can picture that happening at JLR but not in a Japanese company.
Post #661419 9th Apr 2023 11:28am
pld118
Some never pass up an opportunity …
Post #661444 9th Apr 2023 6:58pm
