Home > Technical (L322) > 2010 to 2012 towbar armature VUB503960 |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 654 |
since Horizon Group bought out Westfalia back in 2016, it has been a complete disaster for any parts and stock coming out of the old Westfalia european operations, I doubt relations between JLR and Horizon have been cordial !
14th Apr 2023 5:27pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3203 |
@PeterB
14th Apr 2023 6:59pm |
Peter B Member Since: 26 Aug 2022 Location: Evesham Posts: 30 |
Well I didn't know Westfalia had been taken over, that explains a lot, Horizon group will doubtless only be looking for large scale manufacturing possibilities. I will go down the second hand route them. |
14th Apr 2023 8:13pm |
Anyone know the small modifications required? |
14th Apr 2023 8:15pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
I believe it’s the exhaust hangers. If missing on the tow bar you’ll need to grind the, off the existing bits that are removed.
14th Apr 2023 10:33pm |
OK many thanks, the Westfalia cross members I have seen are shaped. |
15th Apr 2023 5:04pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
As already suggested, just cut the hangers off the bits you remove to fit the armature. They will then be held on with the bolts that you use to attach the armature. 2010 4.4 TDV8 Vogue SE |
25th Apr 2023 12:20pm |
Thanks, the armature I ordered on ebay had already been cut. The bolt holes had been cut off, cunningly hidden by the angles on the photos. Hopefully get my money back.
25th Apr 2023 12:34pm |
You cut your existing hangers off the existing bits you remove to fit the armature.
25th Apr 2023 12:37pm |
The holes in the second picture are drain holes. The mounting holes have been cut off! Picture of what it should look like, with 2 holes.
25th Apr 2023 1:03pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1368 |
Could be easier and less expensive to buy a Tow Trust tow bar. 2015 Range Rover Autobiography 4.4 SDV8 |
25th Apr 2023 6:36pm |
At last I have the armature and electrics. My local independent is refusing to fit it as they won't make money on parts etc. The main dealer refused to fit a new one due to possible problems with rusty bolts etc.If I can get a local towbar specialist to fit, will I then need to get the ecu remapped for the rear sensors?
5th May 2023 4:37pm |
JavaBlack Member Since: 07 Sep 2016 Location: UK Posts: 67 |
I am fairly local and have a GAP tool if you would like any help. I have just finished fitting a towbar aswell. |
5th May 2023 7:11pm |
SilverSpanner Member Since: 28 Jun 2017 Location: Hamilton, South Lanarkshire Posts: 17 |
Mine came off a 2003 MY onto a 2012 MY. It had been a new bar that I purchased and after descaling and fixing the exhaust brackets, I sent to my local wheel refinisher and had it and the detachable tow bar powder coated in the car colour - nice job it is too! Any the main point for my post. I just can't see how the dealer wont fit due to rusty bolts. The attaching bolts are huge, and if they could break them, they must be turning them the wrong way (lol). I would say they are unbreakable, they are something like 16mm bolt diameter. 2012, FFRR Westminster TDV8 - Orkney Grey
23rd May 2023 11:54am |
