Home > Technical (L460) > Engine fan very active on P530 |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2523 |
I suppose there will be higher under-bonnet temps with a hot-vee engine. |
23rd May 2023 11:13pm |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 710 |
I have a P530 and have not noticed a fan come on at all. Long or short journeys. Maybe it depends on how much the turbos have been running beforehand. |
24th May 2023 7:20am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3066 |
check thermostat housing, possible damage? Thermostat misreading internal engine temps? (happened on my 4.4 TDV8) |
24th May 2023 7:58am |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 918 |
This is normal for this engine and emissions tech. It’s to do with the PPF as I understand it. The Audi/Bentley/Lambo V8 does the same.
24th May 2023 10:28am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1344 |
Just by way of amplification of the comment from Autobiography: see the 'Harry's Garage' youtube video on the Bentayga 4.0 in which he comments on the frequent fan operation required in 'hot V' twin turbos. Only Range Rovers since 1988 |
24th May 2023 11:10am |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1075 |
The thing I notice is when I get home and switch off, the fan runs for quite a while. letters not necessarily in the right order |
24th May 2023 11:22am |
I am beginning to wonder if my fan isn't working now |
24th May 2023 7:49pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1266 |
Yes the fans run on from. I was told its so the engine doesn't cook itself, mine does the same and is normal according to factory. Advice I was given was if driven hard or for a long time allow engine to idle for a few seconds before you shut down, that will help as well. |
24th May 2023 8:06pm |
