Home > In Car Electronics (L322) > 2012 Rear Entertainment - Bluetooth headphone upgrade? |
dsm Member Since: 12 Oct 2019 Location: South East Posts: 10 |
Good day all,
25th May 2023 2:13am |
Good news! I put one end of a chopped-up jack lead into the connector pins (picture below), plugged in some headphones and got sound.
27th May 2023 10:17pm |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 258 |
Be a handy way to add a socket for wired headphones, or a BT transmitter to allow the front seat passenger to listen to the audio for a DVD while the front output is muted. Annoys me that the wife can watch a DVD but I have to listen to it while I'm driving. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
27th May 2023 10:30pm |
Install complete. It works, but the sound quality is pretty poor. I need to do some more investigation to work out where the problem is.
29th May 2023 2:09am |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 148 |
first of all you connected two recievers in parallel it is mistake.. You should connect transmiter directly to the plug. Second issue may be impedance mismatch. |
29th May 2023 9:52am |
That's a good point, it sounds like some frequencies are more attenuated than others. I'll buy a new connector and wire the BT transmitters directly to that. |
29th May 2023 3:01pm |
Just finished, and it works like a charm! I believe the L405, Sport, and the Evoque use similar IR headphones so this will probably work on them too.
3rd Jun 2023 4:12am |
