Home > Maintenance & Mods (L322) > P0401-00 EGR Flow Insufficient - what to do? |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 183 |
I have a 4.4TDV8 with 99k and I’ve had the P0401-00 error come up twice in the last 500 miles. It’s easily cleared with the Gap IID tool but I’m mindful that clearing the error is not solving the problem.
6th May 2022 10:42pm |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 152 |
clogged egr cooler. A lot of work to remove and clean. |
7th May 2022 7:43am |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
As a possible “quick win” you could an egr cleaner spray? One where you spray into the intake as the engine is running…
7th May 2022 8:08am |
If you want to consider the egr delete (or looking for a garage to help) then contact Martin at Dartford Automotive… he’s potentially not too far from you. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
7th May 2022 8:10am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2782 |
Check for a split in one of the 4 manifold to intake couplers or a split in the intake donut itself. The ECU will close the throttle plate to create low pressure in the intake to increase EGR gasflow but if there is a leak it won't be able to . Any other drivability issues? Are you doing a lot of short trips? 2012 TDV8 Vogue (L322) |
7th May 2022 8:36am |
GGDR - thanks for the comment. I'm not an expert so don't know either way but I picked the 100k thing up from one of the videos that Matt from High Peak Autos did on the 4.4TDV8 recently. Check it out here about the 9 minute mark. I'm fairly confident that it is not a LR recommended service job like belts might be, but depending upon the driving style and use, surely all EGRs will clog up eventually and need either cleaning or replacing? Do you know why the 4.4's EGRs wouldn't need to be replaced? Andy 2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior 2017 Audi SQ5 3.0 V6T Quattro in Volcano Red 2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration! Last edited by Ajmngn on 7th May 2022 9:43am. Edited 1 time in total |
7th May 2022 9:31am |
FFrr-lover - that's a good idea regarding the EGR cleaner. I've been looking into a product called Revive Turbo Cleaner which seems to get good reviews. These types of cleaners seem much more geared towards turbos than EGRs, so I am interested to see whether they can do anything to help clean the valve, or whether it's just the air intake manifold part where recirculated gases are also being brought in and depositing soot. I've emailed Revive asking for the recommended procedure for doing an application on sequential turbos so I will see what they come back with. I think that I will avoid anything to do with EGR blank/delete, even if done through the ECU, as there are a lot more threads on this forum warning against it for the 4.4TDV8 than there are of people who've done it with any success. However, I'd be more than happy to hear others' thoughts on this... I'll have a look at the WM when I get a chance to work out the locations and routing of the key components but I will certainly check out your suggestion regarding the EGR pipe into intake manifold and have a look. Thank you! Andy 2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior 2017 Audi SQ5 3.0 V6T Quattro in Volcano Red 2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration! Last edited by Ajmngn on 9th Jun 2023 9:11am. Edited 2 times in total |
7th May 2022 9:42am |
JayGee - some really useful tips, I'll have at look at those pipes when I get the chance to investigate further today. I haven't noticed any other drivability issues - it pulls smoothly and decelerates with no judders; it idles at a constant 800ish rpm; and there's no smoke coming out of the exhaust other than the odd time when booting it over 2500rpm when it clears any oil built up in the second turbo (I don't think mine has had the turbo drain mod but can't be sure unless I'm able to look for something that can be seen fairly easily to show it). I picked the vehicle up about 2000 miles ago so can't be sure of it's driving history. However, I've been doing a good mix of driving. It does do a few short trips but I also do quite a few long runs and will also take it out for a drive in the week to give it 20 mins or so on a dual carriageway and run it up through the revs using the command shift to really get the engine working and clear out any deposits etc. I'm minded to give the Revive Turbo Cleaner a go and to try and manually clean any parts of the system that I can access as has been mentioned further up the thread, then just see what happens. However, the vehicle came with a 3 month warranty, that I've already used for a new alternator, and it runs out on 25 May so am minded to take the plunge and use it before the warranty runs out. IThe warranty will only pay £45+vat per hour for labour plus parts, and my local Indy charges £78+vat for labour, so it will cost me the excess of labour charge which would be about at around £400 for a 10 hour job. However, it could be £400 now or a -ton more one the warranty runs out so could well be worth taking the plunge now! Andy 2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior 2017 Audi SQ5 3.0 V6T Quattro in Volcano Red 2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration! |
7th May 2022 10:01am |
I wouldn't waste money on spray turbo/EGR/intake cleaners. When you have seen the kind of crud that builds up in the intake you will know why a bit of spray will do nothing and it may even damage your engine if it dislodges stuff which is then drawn through the engine. Unlike the 3.6 the EGR valves on these engines are vary rarely a fail item. If you still have a warranty I'd use it to sort this out. 2012 TDV8 Vogue (L322) |
7th May 2022 10:08am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
If you need a good specialist nr Surrey then highly recommend www.glenrands.co.uk
7th May 2022 12:12pm |
Update: looking in the WM ‘Diagnostic Trouble Codes’ leaflet it suggested a number of electrical tests for the EGR electrical actuator leading to a potential change of that part if the electrics are sound.
8th May 2022 10:04am |
So, a slightly long(ish) update to this long(ish) running saga…
8th Jun 2023 6:36pm |
The issue here is why it's clogging with soot and not how to clean it i.e treat the cause and not the symptom. I wouldn't put anything liquid in the EGR cooler as unless you get it all out there is a real danger of it being sucked into the engine and it doesn't take much to cause a hydrolock. Blocked EGR coolers on these cars are not a common issue - infact this is the first one I've heard about. 2012 TDV8 Vogue (L322) |
8th Jun 2023 7:04pm |
JayGee, I agree with the symptom/cause conundrum. However, assuming the cooler is partially/fully blocked, chasing the cause isn’t going to unblock it so my priority is to confirm if there is a block and deal with that first before considering causes.
9th Jun 2023 8:11am |
