Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help
Page 11 of 12 <123 ... 101112>
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
Does anyone know why in some cars stop and go works, and in some don't?
It depends of ABS or PCM module? Different hardware, or firmware? Could be updated?
Post #666465 12th Jun 2023 8:43pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
mgrover wrote:
Going to attempt to install on a 4.4 TDV8. i have the slim radar sensor. just need the bracket and wirign now.
Please could you share the P/N for the radar sensor…. I’m looking for one too. I’m trying to determine if there is compatibility with the RR-Sport or early model L405’s as the device serial numbers are similar but the first few characters are different. The L322 4.4 is BH32-9G768-AD. On the RR-Sport and L405’s the first 4 and last 2 characters are different. I think I read on here that this may refer to the device firmware version. And there’s a procedure for upgrading the firmware with the IID GAP tool.
The wiring loom is quite cheap…. £30 or so as I remember. P/N is LR023028
The bracket is quite expensive…. £200. P/N is LR022947 one of the U.K. LR specialists has them in stock.
Please update as you go though as I’m also considering this and will be interested how you get on. TDV8 4.4 2012
Post #666477 12th Jun 2023 10:10pm
mgrover
From what I can tell they are using the same ones from the L405
Same part number which is 28085610
But the firmware is different between L322 and L405
I have a feeling the firmware is BH32-9G768-AD
A quick google of 28085610 produces quite a few volvo results as well. So i wonder if its just a matter of flashing
I just need the loom and bracket. I might attempt to use a L405/L494 bracket since they look very similar.
Loom I think is on back order from LR
edit: Oh wow the bracket for the L405 is LR060076 and only 30quid
Defo worth a punt imo
It's
https://parts.jaguarlandroverclassic.com/l...nting.html
vs
https://parts.jaguarlandroverclassic.com/lr022947-bracket.html
While they defo aint the same bracket, be interesting to see how it lines up, and am sure a few drill holes wouldnt hurt if it needs it Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #666506 13th Jun 2023 11:09am
GraemeS
Gap didn't know if they could flash my Jag unit with L322 firmware but their flashing worked. The Jag unit wasn't recognised as existing in my L322 until flashed.
Be careful using brackets from another vehicle as the unit has to aim correctly, although there's a fair range of adjustment in the adjuster screws.
Post #666553 13th Jun 2023 10:42pm
Ramblin Man
It's
vs
@mgrover how are you getting on ? I’ve just picked up an ACC sensor part no. BH32-9G768-AD with bracket from eBay. I already have the loom and switch gear so I’m all set to start. TBH I’m apprehensive of the adjustment/calibration procedure so any hints and tips would be appreciated. TDV8 4.4 2012
Post #667819 29th Jun 2023 12:04am
mgrover
my local dealer has switched their parts department from the local one at the dealer to some centralised order taker.
nobodys come back to me at all.
ill give them a ring Its actually a sport Sad
Post #667827 29th Jun 2023 8:00am
GraemeS
Line it up by sighting as best you can direct ahead and parallel to the ground should be useful initial aim, then later make minor adjustments if required. Mine's calibration occurred after driving between 2 3-metre or so high steel gateposts, after which the engine has to be switched off, and maybe for a number of seconds as I don't recall the specific procedure, then it was working once the engine was restarted.
Post #667852 29th Jun 2023 12:48pm
Ramblin Man
Thank-you! The sensor is due for delivery today so I’ll be cracking on with the job over the next few weeks Thumbs Up TDV8 4.4 2012
Post #667916 30th Jun 2023 4:49am
mgrover
anyone got a spare wire for sale? LR are completely out haha Its actually a sport Sad
Post #670379 3rd Aug 2023 2:57pm
mgrover
I installed today with the newer bracket.
I did reuse 1 hole and drill 1 new one into the bracket. Also I cut down the adjustment screw since theres no drilling through the bar.
Enabled the settings in CCF.
I get nothing from the CC buttons atm. But calibration with GAP tool all completed successfully so unsure whats missing. Will be checking fuse next.
Settings I use where
Cruise Control: Adaptive fitted
Cruise Control Display: Adaptive speed control full display plus priority messages
JAG Cruise Control: ACC_QUEUE
Also anyone with 50 million different errors after flashing CCF, you need to recalibrate steering angle sensor.
I might set the JAG CC to just ACC for now.
edit:
It already had the fuse, also tried the above no dice.
The CCM module does have an error about invalid instrument panel controls or something, will need to dig deeper
the switch panel i installed was AH42-13D767-BC Its actually a sport Sad
Post #671780 22nd Aug 2023 7:06pm
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
If you have a look at some of the early pages in this topic the guys who first attempted this put up pictures of all the settings they used to get it working. I think you may be missing some of the settings to do with the collision mitigation and braking.
As far as I am aware, none of us have ever managed to get the queue assist to work successfully so I would leave that disabled.
Rich 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #671812 23rd Aug 2023 8:40am
GraemeS
Mine's queue assist worked when tested a couple of times although I don't use it.
Post #671820 23rd Aug 2023 10:30am
mgrover
Rich
those settings dont show up.
do I need to email gap and get an updated version of the firmware? tbf i may need to check if the tool needs updating. Its actually a sport Sad
Post #671827 23rd Aug 2023 12:36pm
GraemeS
Have you applied to Gap for full CCF access?
Post #671828 23rd Aug 2023 12:51pm
mgrover
By full access,
Do you mean activated the car and linked it to the device?
Or is there another level?
edit:
Either way am updating it now, version is still 4, but am a few builds behind
edit:
exact error code is
U0423-81 - Invalid data received from the instrument panel control module - Bus signal/message failure - invalid serial data received(AB).
Is this because the switch panel I am using is from a 2010 car and mine is 2011, so odds are is needs new firmware possibly?
edit:
ive got same issue as andyducati(which ducati is it Andy am dying to know), will email GAP for the extra settings. Its actually a sport Sad
Post #671829 23rd Aug 2023 12:54pm
