Home > In Car Electronics (L322) > 2011 L322 Bluetooth module |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3196 |
Can't assist with models of Bluetooth modules but I would expect different Serial Numbers on different items as they are normally to identify the specific unit. John
13th Jun 2023 8:36pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 521 |
That's true (and pretty obvious to be honest, feel pretty silly now!!). Anyway, I've noticed that some available units have the number BH22 10F845 AA, rather than AH42 10F845 AA and appear outwardly exactly the same. but are they? Drives:
14th Jun 2023 3:34pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34931 |
there's info in the wiki.. ... - .- -.
14th Jun 2023 4:18pm |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 80 |
I was just wondering if instead of using a RR part can we not use a Ford part from the same years? Having looked online at things like the Mondeo, Focus ect the look the same connections... Borrowed Grey 2002 3d 204k for a year
14th Jun 2023 6:39pm |
Stan: the info on the Wiki (unless I'm missing something) seems to be limited to a list of part numbers. I can't find where the part number is listed on the module itself and I'm afraid I don't understand the Wiki post. The other Wiki post seems to be about updating the bluetooth module on earlier cars. I'll have another look. Thanks. Drives:
15th Jun 2023 8:40am |
this seems to be a common problem..
15th Jun 2023 8:50am |
I've done that as well Stan, thanks, but I'm afraid there's nothing in there about the individual numbers on the unit. There seem to be a few available online, but they are all the BH22 type, not the AH42 which is what appears to be fitted to the L322. The question is, are they interchangeable (all connections look identical, but they may not be compatible)? Drives:
15th Jun 2023 11:59am |
i'm sure someone has done this before so hopefully you'll get the answer soon.. ... - .- -.
15th Jun 2023 12:09pm |
Forget all the above, found an AH42 unit! Hopefully it will solve the problem. Thanks all. Drives:
15th Jun 2023 12:14pm |
Just to round this off, replacement AH42 unit fitted and all working perfectly. Happy days. Drives:
22nd Jun 2023 8:40am |
BigEnglishWagon Member Since: 30 Jun 2020 Location: Wellington Posts: 6 |
Did you get a mating 32 pin connector with the module?
28th Jul 2023 6:32am |
