Home > General > What Did You Do In Your Full Fat Today |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 274 |
Fitted a new battery today and all is well again.
21st Jul 2023 7:14pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2695 |
Fitted the spare wheel removing strap system. This should avoid me hurting my back trying to remove the wheel if I get a puncture. Unfortunately I hurt my back removing the wheel in order to fit the straps 2012 TDV8 Vogue (L322) |
24th Jul 2023 5:57pm |
Huttopia Member Since: 26 Jun 2017 Location: Worcestershire Posts: 185 |
Picked it up after having the power steering hoses replaced, happily with original LR parts not aftermarket. |
26th Jul 2023 3:29pm |
joel-h Member Since: 23 Sep 2018 Location: Kent Posts: 35 |
Picked up my new front dust shields which I'll be modifying to be "slide on" rather than "hub out"
27th Jul 2023 6:44pm |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 530 |
1.Installed a MKIV Navi with 2019 maps. As archaic it may be, it's a far cry from the MKIII and something I can actually use The female voice is also a nice break from the...butler's. And matches the voice command, too
28th Jul 2023 6:58pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
Collected from independent. Oil service and replaced air con compressor, condenser,dryer.regas etc. Whilst the front was off had the serpentine belt and tensioner replaced as well.
3rd Aug 2023 5:57pm |
Flashed a very nice "Range Rover" splash screen on the new MKIV and edited the "BMW ASSIST" into... "JLR ASSIST" . Always have the tow truck co. on speed dial, of course
4th Aug 2023 7:01am |
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 73 |
Completed a service, new oil, oil filter, air filters, cabin filter and fuel filter, in between down pours of rain. Oh and purchased a deployable side step kit. Also own a 1976 Land Rover 101 3.5 V8.
6th Aug 2023 9:41pm |
Installed the wiring loom and fully connected it to the various plugs and sockets for my deployable side steps. Steps to be fitted tomorrow. Also own a 1976 Land Rover 101 3.5 V8.
12th Aug 2023 11:06pm |
=dj= Member Since: 24 Oct 2020 Location: New forest Posts: 66 |
Got the wheels refurbished in brilliant silver. I'd had them diamond cut previously which looks great for all of about 6 months before the laquer falls apart and the corrosion sets in...
16th Aug 2023 10:24pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Fitted new rear brake pads and cleaned out the handbrake drums. The handbrake actually works now. |
17th Aug 2023 8:16am |
DannyJeff Member Since: 13 May 2023 Location: Brighouse Posts: 3 |
Finally managed to pin down the slight loss of coolant ( approx 0.2L every couple of months).
18th Aug 2023 12:34pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 511 |
I have clay barred, machine corrected the paint and then polished the car.
18th Aug 2023 12:41pm |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 308 |
Had the tracking done. Was driving quite true but felt something was a little off, I thought maybe at the back but it was the fronts.
23rd Aug 2023 9:40pm |
