Home > Technical (L405) > Engine stops |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 332 |
This may explain it: - LTB01083
30th Jul 2023 9:31pm |
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 191 |
Thank you very much. That describes perfectly what happens.
31st Jul 2023 7:24am |
Thanks Guys I have found all the information I need to give to my Indy tomorrow. 2013 SDV8 4.4 SE Luxor.
31st Jul 2023 8:43am |
I have read all the LR Technical Bulletin. I see that the replacement loom section may be the better way to go.
31st Jul 2023 4:12pm |
I couldn’t locate the part either. So I disassembled the upper (easily assessable) connector and doused it in Servisol Switch and Contact cleaner.
31st Jul 2023 5:08pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Correct repair is a new electrical connector for the rail pressure sensor, which comes with a length of wiring to remove the connector at the top of the cam cover
31st Jul 2023 7:42pm |
Thanks Mike, that’s exactly what my Indy said. Britpart.have them, unlike LR. So as soon as it comes, it will be fitted. 2013 SDV8 4.4 SE Luxor.
2nd Aug 2023 8:20am |
Wire fitted. No further problems. 2013 SDV8 4.4 SE Luxor.
28th Aug 2023 4:04pm |
Bikeracer Member Since: 24 Aug 2023 Location: Newark Posts: 10 |
Thank you very much for that explanation, my L405 is behaving in exactly that way. I have sent a copy of your information to my Range Rover man and I hope to get everything sorted in the next few days. |
29th Aug 2023 6:50am |
