Home > Technical (L405) > MY19 deployable side steps |
rstoughy Member Since: 17 Dec 2022 Location: Stonehaven Posts: 21 |
Maybe unplugged?
3rd Aug 2023 7:41am |
madasmad Member Since: 22 Mar 2020 Location: Cheshire Posts: 83 |
Thanks RStoughy, do you happen to know where I would find the plug please? 2019 Autobiography SDV8 Byron blue/black - current
3rd Aug 2023 1:35pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1136 |
Hi, Have you checked the fuse's right side rear? The information screen has an on/off button.
3rd Aug 2023 2:40pm |
Thanks Tinman, I tried the put it in neutral etc but it sadly didn’t work. I found the fuses in the right hand side of the boot but how do you get to them? I have taken a picture.
3rd Aug 2023 9:56pm |
Hi, it's in the sidewall right side you have to lever it out from the top, mine is number 39, 30amp green.
4th Aug 2023 9:29am |
Hi, have a look here.
4th Aug 2023 9:56am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16185 |
Look underneath at the motor end of the step and you should see the big electrical plug sir... Is it plugged in? |
4th Aug 2023 10:57am |
Thanks guys. I will take a look at both of these options. I will let you know how I get on 2019 Autobiography SDV8 Byron blue/black - current
4th Aug 2023 12:03pm |
So back from holiday-
16th Aug 2023 12:08pm |
