Home > Technical (L405) > What’s making the whooshing sound? |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
Glad you got it sorted Kev
21st Aug 2021 9:28am |
goddo Member Since: 27 Oct 2020 Location: south Posts: 78 |
That racket must have driven you nuts. Glad you got it sorted. |
21st Aug 2021 9:55am |
L405RRAndy Member Since: 28 Jun 2021 Location: Essex Posts: 2 |
Has anyone managed to get to the bottom of this or find out any more info?, mine makes the exact same noise 2015 SDV8, bought it at 80k and now on 86k noise is no better or worse, replaced all the belts, tensioners + alternator and still no difference. Definitely something inst right, more pronounced on trailing throttle 1100-2000 rpm, Thanks Andy |
5th Oct 2021 6:25pm |
FF777 Member Since: 21 Jan 2022 Location: London Posts: 17 |
Anyone had this diagnose? I've got exactly the same issue |
25th Jan 2022 12:20am |
Hello again
16th Sep 2022 4:21pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 595 |
Thread resurrection but... did you ever figure this one out LT?
5th May 2023 7:42pm |
LT Member Since: 13 Mar 2017 Location: South West Posts: 394 |
No, it is still there and variable between hardly noticeable at all to how it was when I first noticed it.
17th May 2023 4:55pm |
Thanks for the reply LT.
21st May 2023 10:43pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16187 |
Tis usually the cover under the gearbox... There is a 2mm thick metal bracket with a tin temperature resistant aluminium cover that spans most of the plastic gearbox sump... The metal bracket usually fails by cracking! Only way to diagnose it is to remove the 4 10mm bolts that hold the aluminium cover on and inspect the bracket above... |
22nd May 2023 1:05am |
SamDubs Member Since: 26 May 2023 Location: West Midlands Posts: 2 |
I have also had this exact cooing/whooshing/resonance issue for the last 18 months (2017 SDV8), so have been following closely.
8th Aug 2023 1:06pm |
The broken brackets make the kind of resonance you would hear in a bus or a plane. Not a pigeon coo’ing noise BUT… Noises are very subjective! Well worth checking the bracket/cage has not fractured sir… |
8th Aug 2023 1:14pm |
Cheers for the quick reply. Maybe the pigeons are different here in Worcestershire...
8th Aug 2023 2:29pm |
evotime Member Since: 02 Apr 2021 Location: Aberdeenshire Posts: 127 |
Possible cause is the Torque convertor oil pump blocked/ falling or possible low oil level in gearbox making the pump struggle.
9th Aug 2023 10:03am |
Oil pump has been changed for a new one and gearbox oil has been drained twice (as much as is possible) and refilled to the correct level.
9th Aug 2023 2:03pm |
