Home > Maintenance & Mods (L322) > Air Suspension issue. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2323 |
You could just replace the bag and possibly the other side too as its condition won't be much better but if the shocks are well-worn then best to replace both assemblies, not just 1 side. The rear bags don't have the same issue as the fronts but if fitting new front asemblies then you'll most likely feel that the rear shocks also need replacing. |
14th Aug 2023 2:08am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2786 |
Are you sure it's the air spring as it could be the air hose, joint or valve block that's leaking. 2012 TDV8 Vogue (L322) |
14th Aug 2023 7:08am |
Seftona3103 Member Since: 13 Aug 2023 Location: Bedford Posts: 4 |
No not really sure where it is leaking. All i know is that you can hear air coming out worse when on off road height.
14th Aug 2023 10:06am |
Thanks for the info. If I need to replace I will replace both fronts first and see how it is. |
14th Aug 2023 10:08am |
Just spoke to one of the guys who said he could feel the air coming out the back so he think its the Air spring.
14th Aug 2023 10:34am |
Sprayed soapy water will show leaks from the airsprinng. |
14th Aug 2023 10:41am |
