Home > Wheels & Tyres > Spare tyre age |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7797 |
I'm sure a lot of spares are as old as the car.
19th Aug 2023 8:04am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34947 |
i agree with Alistair re using it as a get you home [with care] spare... ... - .- -.
19th Aug 2023 8:52am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2755 |
Get rid of it and buy a full sized matching wheel and tyre. The space saver won't get you very far or do it very fast so unless you are close to home you will be forced to drive to the nearest tyre fitter and hope they have a matching tyre in stock or buy something cheap to get you on your way all of which can be a major PITA. All this assumes you have a major tyre failure and not a simple nail puncture that can be easily repaired with a DIY kit. 2012 TDV8 Vogue (L322) |
19th Aug 2023 9:13am |
rambles post refers to a full size tyre?? and not a 'space saver' ... - .- -.
19th Aug 2023 9:16am |
19th Aug 2023 9:31am |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 154 |
I do the same as Alistair, use it and keep the another as a spare |
19th Aug 2023 10:23am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3655 |
Yep I use mine as Alistair, well I used to. I've now got 4 spanking new tyres on 22" style 706 wheels, a genuine 22" turbine as spare and 4 more 22" genuine turbines cluttering up the place (according to SWMBO). Must have a clear out. Back on topic daughters car had cracked tyres on car resulteing in MOT advisory's- maybe should have been a fail. Obviously the spare is not relevant/checked. Geoff |
19th Aug 2023 11:01am |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 |
When I had my L322 I replaced all 5 tyres (I had a matching alloy spare) with new and rotated them all periodically.
19th Aug 2023 12:16pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
@Sam: Tyre age is an MOT test requirement for some passenger vehicles already:
19th Aug 2023 1:08pm |
That's interesting Gremlin & thanks for posting the details.
20th Aug 2023 12:17pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2224 |
I change from summers to winters so at the moment have the summers on and a winter as a spare and in winter the opposite seems to work for me |
20th Aug 2023 8:19pm |
Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109 |
The thing that kills tyres is UV. I'd actually be more inclined to leave a totally unused ten year old tyre in the boot than leave a part worn in there for less time. From the factory tyres come with UV inhibitors and oils on the surface that help protect them. Using them gets rid of this protection which leads them to degrade. That said you could easily spray a used tyre after thorough cleaning with something like 303 Aerospace which will help keep the rubber supple. I've got a set of old 18" wheels from the Impreza which haven't been used in about 5 years and have 2017 date coded tyres, and got used a fair but but are still at 4mm. When I took them off they were still nice and soft but time has led to significant hardening of them. In contrast the identical brand new spare is still nice and soft. |
20th Aug 2023 10:06pm |
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 134 |
So a spare buried in our 'boot' should last a lot longer then? Chris 2014 FFRR 4.4 SDV8 Autobiography Barolo Black 2012 RRS SDV6 HSE Baltic Blue and before I saw the light: 2011 Suzuki Grand Vitara SZ5 1998 Ford Mondeo V6 Ghia X 1990 Citroen BX GTi 1973 Triumph GT6 |
20th Aug 2023 10:22pm |
Basically, yeah. It'll still age but I really wouldn't be concerned with an old but unused tyre because the tyre still has its protectants on them. And even a used one will still be in better shape than one that's spent the same time outside, under load, heat cycles etc. If a tyre doesn't feel like it's made of plastic and isn't cracked it'll be perfectly sufficient for a spare. There are ways for tyres to become damaged invisibly, but the reality is that they're designed to last a good amount of time in fairly bad conditions. We also don't get the same level of UV in this country as say an alpine village, or the heat of a greek summer, so they just get less abuse than in many parts of the world. |
20th Aug 2023 10:43pm |
