Home > Technical (L322) > Tow Bar Help Please |
beemer5711 Member Since: 01 Aug 2022 Location: Wales Posts: 72 |
Thanks. When you say software will ask what type of trailer is connected, is that on the dash? |
30th Aug 2023 8:50pm |
Thanks again |
30th Aug 2023 8:52pm |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 |
Thanks. When you say software will ask what type of trailer is connected, is that on the dash?[/quote]
31st Aug 2023 1:25pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1367 |
I think that only applies if trailer assist is fitted / activated. My infotainment screen doesn't display anything when connected, just the trailer icon on the driver display. 2015 Range Rover Autobiography 4.4 SDV8 |
31st Aug 2023 2:10pm |
Can tow assist be turned on on any car?
31st Aug 2023 4:21pm |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 93 |
If replacing the whole thing try PF jones and go for the westfalia one (2 options one with detachable and one fixedish ) there wiring kit is also plug n play on a 4.4tdv8 with no programming required unless you want the fog lights deactivating (2x7 pin anyway), re fitting (I've done a couple) its bumper off and nuts n bolts , a bit awkward round exhaust but not that bad . I use the one with the square hole receiver type hitch that slides in and is locked by a big pin but have put the full detachable hitch (like the D3/4type swan neck) on someone else car for them , dragged caravan's and car transporter trailers round for 7ish years now with no issues . (just watch your speed as it's very easy to hit 80/90 whilst overtaking with van on back ). |
18th Sep 2023 11:25pm |
Answer 2 regarding electrics , my caravan has normal bulbs and when connected bottom left of main dash has a little trailer logo in green that flashes when indicating , it also works fine when I have Thule bike rack on and that is full led , don't know if Thule fit load resistors though . |
18th Sep 2023 11:30pm |
Thanks to everyone on here, your help has been great.
20th Sep 2023 10:20pm |
