Home > Technical (L322) > access mode |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
No, but I find the LOWER button on the driver's door handy. |
28th Aug 2023 9:37pm |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 124 |
Yes but by the time I get to press the button somebody has already opened their door which cancels it .
1st Sep 2023 10:51pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1356 |
I have my tool unlocked with the whole CCF catalogue. I'll take a look when I get a chance and see if there's anything in there.
1st Sep 2023 11:02pm |
Press the door button as you slow.
1st Sep 2023 11:40pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2705 |
I'd avoid unnecessary suspension lowering and raising to preserve the life of the compressor. If you need help getting in and out then maybe concider some sidesteps? 2012 TDV8 Vogue (L322) |
2nd Sep 2023 7:47am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 762 |
Had no problems with my compressor last 12 years
2nd Sep 2023 9:39am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
As above Got - 2017 SDV8 Autobiography in Loire Blue
2nd Sep 2023 9:55am |
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 34 |
Also dropping to an access mode every time I park.
2nd Sep 2023 9:59am |
I'm not frightened at all. Just don't need it and have never understood the concept that a mechanical device lasts longer if it's used more than if it's used less and by less I don't mean never used which is not the same. 2012 TDV8 Vogue (L322) |
2nd Sep 2023 10:05am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7914 |
Auto dropping came with the 2016MY L405 IIRC....
2nd Sep 2023 11:33am |
Bought my Fatty 18 months ago and I am not afraid to use every aspect of this terrific machine when required.
2nd Sep 2023 12:17pm |
Mine gets lowered when parked at home and when parking when my wife with her dud back is in the car. It also gets raised 35mm for driving my 2km rough driveway and at least the same if not off-road height or even super-extended height anytime the council road is a series of bog-holes. All airsprings have been replaced after becoming porous from the rubber rolling up and down on dried gritty mud (now regularly hosed-out at super-extended height) but the compressor is still original, although I suppose that I've jinxed it now! |
2nd Sep 2023 12:23pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1119 |
Dropping it makes it harder for the barstewerds to nick your Cat as well. |
2nd Sep 2023 1:54pm |
Thanks to all replies, access problem solved. RR owner |
2nd Sep 2023 2:05pm |
