Home > Technical (L322) > 4.4 tdv8 started smoking. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1140 |
Thank God for that!! |
9th Jul 2023 9:15pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4252 |
Oil pump is one place to look to cure smoke screens.
13th Jul 2023 7:44pm |
beemer5711 Member Since: 01 Aug 2022 Location: Wales Posts: 72 |
Hi Kevin, I've just read through this thread, I'm glad you got lucky with it not being turbos. Did changing to Helix cure/reduce oil from 2nd turbo being burnt off? Also, where is the 2nd sump? Can't seem to find anything online. I've had my car a year now and around 9k miles. For the first 5k it would smoke on occasion when using big turbo (not had mod done). I then done an interim oil change, (no oil used according to the dash). Now it smokes a bit more often. She's due a service now and in the last 4k miles I've added a litre, which I don't think is unacceptable, especially as she's getting a little leggy now. However, its more than she was using before the change. I noticed straight away it was a bit more smokey and have thought from the beginning maybe it's the oil. Of course, I have no idea what the oil was that I took out. Oil I'm using is Fuchs Titan GT1 5w30. It was from opie oils, but they no longer list it for my registration. |
15th Sep 2023 8:54pm |
Spoke to Opie Oils,
17th Sep 2023 12:01pm |
To sum up my experience with Smith and Allan oil.
17th Sep 2023 8:03pm |
Great. That’s what I’ll get now for this service. Thank you.
17th Sep 2023 8:14pm |
17th Sep 2023 8:43pm |
Thanks again! |
17th Sep 2023 8:46pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2790 |
Oil viscosity will not be exactly the marked grade as it's a range so some oils will be thinner or thicker at the same grade for a different brand and at different temperatures. Since using S&A I've had no smoke from mine and it's never used any between services. 2012 TDV8 Vogue (L322) |
18th Sep 2023 7:06am |
Yes JayGee, but I would have thought any C1 spec oil should perform the same. Unless parts of my engine are worn 'different, more advanced' than yours who knows.
18th Sep 2023 8:51am |
Not many oils are fully/truly 'synthetic' and the ones that are cost ££££. Also fully synthetic oils are not as good at holding soot in suspension so it's a tradeoff between max performance with regards to friction reduction, heat capacity and film strength and service intervals. S&A may not be the best oil you can buy but if you are changing regularly at 5-7k intervals it's not bad for general use. If you were doing a lot of hard driving, towing, offroading and putting the engine under max loads regularly then I'd probably opt for a more expensive oil. Shell helix 'may just be at the upper limit of what is classed as a 30 grade and doesn't thin out as much as S&A but then again S&A may flow better when cold so helping scavenge the 2nd turbo sump? Smoking 2nd turbo and oil use may not be directly related. 2012 TDV8 Vogue (L322) |
18th Sep 2023 9:30am |
Apparently Shell Helix is made from natural gas and has 50% less evaporation rate than conventional oils. So I think the S&A oil I used is now vapourised which explains everything. |
18th Sep 2023 11:05am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 654 |
At £10 quid a litre it should be good
19th Sep 2023 3:29pm |
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 113 |
Don’t S&A have some sort of link with Shell anyway? |
19th Sep 2023 10:20pm |
