Home > Maintenance & Mods (L405) > ARC/ACE issues... New front and rear pipes |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7941 |
Rear pipes delivery date keeps getting pushed back, now saying 3rd Oct, we're away till mid December a week after so I hope it turns up soon... Pete
28th Sep 2023 3:08pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16185 |
Oh no, that’s a pain Peter… So much is on back order at the moment! Annoying to say the least! |
28th Sep 2023 3:20pm |
It sure is, I'm beginning to have withdrawal symptoms...... Pete
29th Sep 2023 12:07pm |
Well I went to pick up the rear heater hose/pipe as the ARC pipe still hadn't turned up and it was something that could be done in the meantime...
2nd Oct 2023 5:09pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
With an operating pressure of 180Bar, I wouldn't be using copper pipe or standard compression fittings, there are plenty of options for that size and pressure though. |
2nd Oct 2023 7:16pm |
David, Robins a really nice guy, come down for a trip in your new one...
2nd Oct 2023 7:24pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1699 |
We've one in tomorrow with a "hydraulic leak" and red warning on the dash
2nd Oct 2023 7:32pm |
10L steel compression through fittings are about £3.50 each, rated to 500Bar. 10mm OD 1.5mm wall steel tube is about £6 a metre. Given the cost and increasing scarcity of supply, I may well 'roll my own' when the time comes - Pete, can I grab the end fittings off you? there only needs to be 150-200mm of tube beyond the fittings to be useful. |
2nd Oct 2023 7:35pm |
Mikey... weird, it was showing it was supposed to be with the distributer tomorrow and with them on the 4th or 5th... it's been put back and back... maybe a new load has come through.... oh well, got them both now, and the heater pipes....
2nd Oct 2023 8:17pm |
That's fine mate, I can always braze some new stubs into the end fittings, I'm thinking of making the ends up ahead of time so if/when the day comes, it'll just be a case of forming some tube to fit and nipping up a few compression couplers. |
2nd Oct 2023 8:26pm |
Some good progress today....
4th Oct 2023 9:29pm |
Cracking job there!
4th Oct 2023 9:43pm |
A few points for anybody doing this in future,
6th Oct 2023 4:20pm |
Nice job there Pete, the ground stud is an annoyance but better now whilst you have good access & time than whilst you're driving at night in the rain... |
6th Oct 2023 6:26pm |
