Home > Technical (L322) > L322 - Torque Converter Symptoms and advice |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 247 |
you could put in a second hand gearbox and tq .............or have you tried a couple of tubes dr tranny lubegard .im sure ive read some ppl have used this and had some good results 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
2nd Oct 2023 8:44pm |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 36 |
Good advice, I’ll give it a go as not much to be lost I suspect.
2nd Oct 2023 9:08pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 377 |
I don't know for sure with your particular gearbox, all of my L322 auto gearbox issues were with my 2002 4.4 Petrol with the ZF 5hp24 gearbox. The gearbox is a known weakspot with the early BMW engined V8 petrols (M62 engine), but not anywhere near as bad as the TD6 L322's with the GM box.
2nd Oct 2023 9:58pm |
Thanks for the reply Jon, some useful points;
Yes that is exactly how it feels - usually only lasts for a second or three but that is what its like for sure.
That would be joyful
Thanks, solid advice which I'll follow-up on. I'll try to update when I've had chance to get it looked at - which is easier said than done as I've had two garages basically turn me down and my usual garage is giving me "go away" quotes so I'm finding myself going down lower and lower on the garage food chain to find someone interested in working on it. |
5th Oct 2023 12:43pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Dartford Transmissions and Autocare. LR and gearbox specialist Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
5th Oct 2023 1:37pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
Have you checked for brakes binding by any chance. I had vibration similar to yours but turned out to be a binding rear brake. |
5th Oct 2023 2:31pm |
Thank you Sir. |
5th Oct 2023 3:32pm |
Next time I have it out I'll see if the calipers are unusually hot but not noticed that. I hadn't actually thought of this as the vibration definitely feels more "centred" on the car when it does it. Finally got it booked in at a local LR place 25th this month for a pre MOT inspection, they are going to spend an hour or so going through it to spot any obvious issues that would be a headache at MOT time so I'll ask them to double check. Appreciate the advice chaps, knew you lot wouldn't let me down J |
5th Oct 2023 3:37pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 218 |
Had this on my 2008 3.6 tdv8, changed gearbox oil and put some dr tranny in it which cured it for about 4000 miles then I started feeling shudder again going uphill so recon torque converter and bridge seals changed plus oil and filter again and all good again. So my thoughts are torque converter on its way out if you leave it too long it will break up and kill the box. |
5th Oct 2023 10:28pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1364 |
Sounds like the torque converter to me. Dr Tranny will help with idle shudder but not the symptoms you're describing.
5th Oct 2023 10:58pm |
Thank you gents. I’ll update when I can.
5th Oct 2023 11:34pm |
It might be just a bit worn out after 190K though! Also, in my experience the transmission can get pretty mullered from the TC's own friction material if driven on for too long, i.e. not caught early enough. Given the OP want's to carry out an economically viable repair, there are loads of low mileage gearbox's and TC's for not a lot of money available. The low cost is testanment to the fact there's not a lot of demand second hand as they don't go wrong very often.! How about this one from a low 60K mile L322 at £500: https://www.ebay.co.uk/itm/295362620915 Or if you're feeling brave and handy with the spanners, stick a new oil pump on the front of this one at only £150: https://www.ebay.co.uk/itm/354967655334 There's loads out there for around the £500 mark! Jon 1992 RR Classic 3.9 efi Vogue =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
8th Oct 2023 11:35pm |
Thanks, useful. I've found a place very local to me that specialises in ZF gearboxes - I'll drop in there this week and see if they can book it in for a fluid change and eyeball the quality of the fluid that comes out, as previously suggested this should give me some indication of where things are at. Hopefully they will be on the same page and not go off plan ............ or at least my plan! Thanks again, Jon |
9th Oct 2023 9:46am |
OK so this is getting to be a pain
9th Oct 2023 11:59am |
