Home > Maintenance & Mods (L405) > Sway bar end link trials |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1104 |
Dont take this as a flame.
8th Oct 2023 8:44am |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 221 |
The thread pitch is finer. That may affect a max torque to failure rating; however, 185 NM is the spec and far below the max torque to failure rating. The stud size remains the same.
8th Oct 2023 4:01pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
You don't need to compress the suspension to torque up the droplinks - they're ball joints so will turn as the suspension moves.
8th Oct 2023 9:55pm |
Thanks. Regardless of compression, I have difficulty getting them to stop spinning to reach torque. The Moog parts worked perfectly to torque. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
9th Oct 2023 12:57am |
All we use for jobs like that is one of these in the torque wrench
9th Oct 2023 8:43am |
Thank you!
9th Oct 2023 5:06pm |
Those 'plug in' to the torque wrench in place of the ratchet head, you can get versions that are essentially a ring version of a crowfoot wrench that has a 1/2" square drive hole in it.
9th Oct 2023 5:37pm |
Thank you so much. I had not seen interchangeable head tools before.
9th Oct 2023 5:43pm |
Just check the ratchet assembly is removable - not all are, there will be a ~4mm hole where you can insert a pin to depress the spring loaded locking peg. |
9th Oct 2023 6:20pm |
