Home > Technical (L322) > A challenge for the masters of this group |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
Body ground connections (“earths”) corroded?
16th Oct 2023 9:29pm |
Proftinkerpot Member Since: 23 Dec 2022 Location: County Antrim Posts: 165 |
Could there be damage to the fuse box?
16th Oct 2023 9:35pm |
50clarke50 Member Since: 16 Oct 2023 Location: Sheffield Posts: 6 |
Thanks for the ideas guys, the body earths all look good and so does the fuse box, I initially suspected the BCM but after purchasing a new one I found out it wasn’t at fault, although I only plugged it in and quickly tested, not sure if I was supposed to have it coded etc
16th Oct 2023 9:49pm |
All fixed at last! Faulty ignition switch, when tested between the fuse (40 or 41) was only reading 3.5 volts instead of 12 |
5th Jan 2024 8:22pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7647 |
Excellent news. Onwards and upwards with the 4.4 then…..
5th Jan 2024 11:17pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16188 |
8th Jan 2024 1:44am |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 129 |
Well done, I was really feeling for you there. RR owner |
8th Jan 2024 3:39pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2993 |
Nice find! Bet your chuffed it’s fixed now! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
8th Jan 2024 10:29pm |
