Home > Maintenance & Mods (L405) > Dummy obd port….any good |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 354 |
Yes, I use a simpler version as a security item. All it is is a OBD plug which connects into the original socket and a OBD socket which replaces the proper one under the dash. Items plugged in to the OBD show power, but it's not possible to get connection to the car.
23rd Oct 2023 3:16pm |
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 167 |
Time and the added siren right in the area of the obd port might put them off??
23rd Oct 2023 3:49pm |
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 125 |
I understand y'all are having a Rover theft pandemic over there.
27th Oct 2023 12:04am |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
I have simply disabled my obd port instead of relocating it. But in such a way that it can be quickly re-enabled very quickly should I need to use it. Kev
27th Oct 2023 7:58am |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
I have the simpler one without the siren, to all appearances the car looks exactly the same, so I can’t see how a thief could notice it, everything is hidden behind the lower panel, and you can tuck the extra wiring up out of the way. Downside is wear & tear on the screws and fittings and OBD socket itself from repeated access when you need to do diagnostics/monitor soot levels etc it also becomes inconvenient. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
27th Oct 2023 9:44am |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 61 |
Sorry to resurrect an old thread but what about just taking the fuse for the diagnostic socket out? or even rig up a discreet switch I don't know if isolating the power or the canbus to the socket would be better. |
10th Dec 2023 2:38pm |
Wouldn't isolating power to the gear selector do the same thing?
10th Dec 2023 4:36pm |
Yesss! I'm the process of swapping out a Range Rover sport gear shift lever in place of my spinny knob.
10th Dec 2023 5:06pm |
I decided to make a blanking plate to cover the OBD port. There's already a screw near to it which cab be used and another self tapper completes the job. With that and the fuse out it should at least slow them down but if the Wife ever needs to call the AA she'll have some explaining to do. |
12th Dec 2023 3:58pm |
So that is how they are stealing them? Tapping into the OBD port?
12th Dec 2023 4:47pm |
