Home > Maintenance & Mods (L322) > Superpro Bushes |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 183 |
A potentially controversial topic…
27th Oct 2022 1:31pm |
If you’d like to do a bit of education and understand the differences between Superpro and other polybushes, this is probably the best video that I have found out there. 25 mins long, but really does cover a lot of ground and very useful info
27th Oct 2022 1:41pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Fitted them to my own D3, and a family members D3
27th Oct 2022 7:57pm |
Mikey, noting your legendary status in this community, that’s a HUGE endorsement and confidence inspiring to give it a go myself!
27th Oct 2022 8:33pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2705 |
Fitting standard bushes to front upper and lower control arms and rear toe arms 'tightened up handling' significantly on mine but has made the ride harsher. One advantage of all of these aftermarket bush designs is that they are easier to fit that stock as they don't need pressing in with special tools. I've fitted polly bushes to other cars for this reason alone. 2012 TDV8 Vogue (L322) |
28th Oct 2022 8:54am |
I cant compare handling, as I went from standard ARB's to Active Roll Control (Hydraulic ARBs), various RRS suspension arms, RRS front struts and D4 rears, as well as a full set of Superpros So it handles nothing like a Disco anymore It is, however, much more fun to throw around and surprises quite a few people unable to pull away from a small house |
28th Oct 2022 8:34pm |
So, about a year on from my original post I have finally fitted Superpro bushes to my front lower arms.
30th Oct 2023 9:06pm |
Great job! How much was the bush set for the front as I guess most people would opt to just reuse their existing arms? 2012 TDV8 Vogue (L322) |
31st Oct 2023 8:51am |
I found all the parts from a company called ML Performance. All the parts were being offered at a discount when I bought this so I’d imagine it would be over £600 if one bought the same at full price. Here’s the order invoice
31st Oct 2023 9:08am |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 392 |
Great post, thank you for sharing
31st Oct 2023 12:41pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
Some time ago I fitted for a very short time a 2-piece poly bush with a centre tube set (Powerflex) that I found unacceptably harsh on any surface that wasn't very smooth.
31st Oct 2023 9:19pm |
Graeme, they are single piece bushes with a separate outer sleeve a centre tube.
1st Nov 2023 7:19pm |
Thanks Ajmngn. |
1st Nov 2023 9:14pm |
SuperPro advised that the compound in these bushes is 80 Duro. Their range is 70, 80, 90 and 95 Duro.
3rd Nov 2023 8:22am |
