Home > In Car Electronics (L405) > Update (sort of) for my USB woes in 2017 AB |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
Hi Damian, I think I’ve tried to help you with this before.
6th Nov 2023 12:51pm |
DamianK Member Since: 04 Aug 2023 Location: West Sussex Posts: 57 |
Hi - thanks for the reply.
6th Nov 2023 12:54pm |
I had a lot of weird issues wth my car when it arrived March 2022, then I got one of these:
6th Nov 2023 1:21pm |
Thanks for this.
6th Nov 2023 3:06pm |
Hi Damian, it’s defo worth checking out the battery, because it’s an easy (if not cheap) DIY fix.
6th Nov 2023 3:40pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Have you checked that the phones are compatible with the car? It could be that they are just too new, I know you said the interface software was updated but this won't automatically mean later phones will always work seamlessly. |
6th Nov 2023 4:48pm |
Hi - that did cross my mind but actually when it works it works without issue, to me it feels like the car misses some sort of handshake maybe with the phone but then I am not sure why it works sometimes and not others (but always doesn't when the car has sat overnight).
6th Nov 2023 4:51pm |
Hi - the more I think about it the more I think the issue could be the battery - I mean that would explain why it never works when the car has sat for a long time (like overnight) but does later after its been driven for a little while. It has the original battery which is now over 6 years old so I am thinking it might be worth replacing it anyway before the winter. I have seen Halfords do a fitting and a battery which will be so much cheaper than taking it to my local dealership! |
7th Nov 2023 1:02pm |
Jase71 Member Since: 13 Apr 2016 Location: Portsmouth Posts: 479 |
Do you need to replace both batteries or just the one under the spare wheel? I'm seeing weird issues on my 2017 car with original batteries 2017 Range Rover Vogue V6 Diesel
8th Nov 2023 11:53am |
I am having the starter battery (one under spare wheel) replaced on Friday so will let you know if that helps - the other battery I think is just for the start/ stop BUT could be wrong.
8th Nov 2023 12:02pm |
Both:
8th Nov 2023 4:17pm |
I am going to replace it whatever as it is the original 2017 battery so might as well.
8th Nov 2023 4:27pm |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 285 |
Out of interest - do you have the InControl app on your phone to access the vehicle remotely - and if so, does it lose connection to that overnight as well as your CarPlay woes? Or does it still work? FFRR SDV8 Autobiography |
8th Nov 2023 4:53pm |
I do have the app yes.
8th Nov 2023 4:55pm |
