Home > Maintenance & Mods (L322) > Gutted broke down had to be recovered ..update.. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1463 |
blocked dpf, low pressure fuel lift pump? BMW i3 Electric Car
5th Nov 2023 2:29am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3704 |
Sounds like fuel starvation - when was the filter last changed, or perhaps contaminated with water. I also had similar symptoms with a new RR Classic in 1987. It was a rubber fuel tank seal that had dropped into the tank on assembly and had been sucked up by the fuel intake pipe blocking off the fuel supply. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
5th Nov 2023 7:27am |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 334 |
No warning on DPF could be fuel pump 2012 Range Rover Westminster 4.4 TDV8 2006 Discovery 3 HSE 260k miles and still going strong with a new owner |
5th Nov 2023 9:02am |
New LR filter fitted Tuesday done about 200 miles, not been through any standing water and only use V power it’s parked up at my mechanics so I’ll hopefully find out Monday 2012 Range Rover Westminster 4.4 TDV8 2006 Discovery 3 HSE 260k miles and still going strong with a new owner |
5th Nov 2023 9:03am |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 391 |
I'd be checking the new filter, is it possible to fit it incorrectly and it foul/get sucked into the system enough to bllock? First time FFRR owner |
5th Nov 2023 9:36am |
Garage had a look today it’s thrown the timing chain on the lhs as you look at the engine 😡😡 took a look through tje oil cap hole and it’s lying to one side, next question is it an interference engine is it fubar 2012 Range Rover Westminster 4.4 TDV8
14th Nov 2023 11:04am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1140 |
https://fb.watch/oj1g3bTfvS/
14th Nov 2023 11:28am |
that does give me hope thanks for posting that 2012 Range Rover Westminster 4.4 TDV8
14th Nov 2023 11:37am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2995 |
Yikes, that’s really, really rare on a 4.4 TDV8. A seriously bad bit of luck!
14th Nov 2023 9:19pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1276 |
My 5.0 v8 Supercharged L405 had an engine rebuild after it slipped a cog on timing chain, it now runs better than ever in fact just like its rolled out of factory. If you need a good garage as a recommendation then happy to provide details, only trouble is that its in Essex but very worth travelling for. let me know if you need details. Good luck and hope it's not too bad. |
14th Nov 2023 10:15pm |
Hi Drf can you send details please ive got a few leads one is by the garage who did the video earlier in the thread £4500 to collect, replace timing chains etc, an extra £700 per cam shaft if there damaged so potentially £6800 or range rover engine specialists in Essex (could be the one you used) a full reconditioned engine £7500.00 but only 6 months warranty 2012 Range Rover Westminster 4.4 TDV8
17th Nov 2023 4:28pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 654 |
Also contact my guys in Barking ( South East Essex ) Tel 020 3542 0100
17th Nov 2023 5:16pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16192 |
Wifeys has just gone pop! Ive chosen to buy a damaged car and remove the engine! Worried me going down the rebuild route, as JLR don't sell any engine parts! |
17th Nov 2023 11:38pm |
That’s a worry I’d do the cam belts myself it’s the getting the engine out etc now I’m in a dilemma bloody cars 2012 Range Rover Westminster 4.4 TDV8
18th Nov 2023 2:11pm |
