Home > Technical (L322) > Battery Backup Siren |
Blackbird51 Member Since: 22 Sep 2011 Location: Portadown Posts: 39 |
Found it. Offending item removed and replaced. |
29th Aug 2020 2:33pm |
Westridge177 Member Since: 12 Oct 2021 Location: Birmingham Posts: 16 |
Where was it? |
21st Nov 2023 9:23pm |
The unit is located on bulkhead below the abs unit. To access remove front driver side wheel and release plastic inner guard. You should be able to get access by removing bottom screw and clip and just one of the upper crews. If I remember properly there is only one screw holding unit in place.
22nd Nov 2023 1:13am |
