Home > Maintenance & Mods (L322) > Restricted performance 4.4 tdv8 |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 325 |
whats it go into Its actually a sport
30th Nov 2023 2:55pm |
BeneVato Member Since: 30 Nov 2023 Location: Tbilisi Posts: 4 |
I attached picture.
30th Nov 2023 2:57pm |
sorry I mean other end. Its actually a sport
30th Nov 2023 2:58pm |
It's from vacuum solenoid.
30th Nov 2023 3:01pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
The way that mine heads backwards after dropping down the front, I suspect it is LR022879 which connects to the turbo. I would have to remove the sump cover to confirm where it ends-up. |
1st Dec 2023 9:11am |
Charles159621 Member Since: 21 Feb 2024 Location: Hampshire Posts: 1 |
Hello I’ve had these codes since owning my car, I’ve had it about 4/5 months, I’ve checked the actuator and it’s moving freely, however it is the old style with the nut on top, I’ve just got a new vacuum hose for the actuator to see if that makes a change
21st Feb 2024 10:11pm |
id take the solenoids off and apply 12v to them, if they click, id fire in some carb cleaner and keep toggling them on/off.
22nd Feb 2024 10:11am |
The solenoid mounted on the shut-off valve is part of the shut-off valve, not a separate part. |
22nd Feb 2024 11:03am |
