Home > My Range Rover > Back with another Supercharged! A 5.0 this time!
Page 11 of 12 <123 ... 101112>
Happy birthday to your little man David... Bow down
And congrats on the 5.0 work sir Very Happy
Post #680040 11th Dec 2023 12:29am
dhallworth
Unfortunately, when using the car on Tuesday last week it became apparent that the caliper was still causing problems.
Land Rover are £580 for a rear caliper and after market ones are much cheaper but are still the best part of £200. They’re bigger on the 5.0 SC and 4.4 TDV8 then they are on the earlier cars so they seem to be much more expensive.
A quick look on the internet saw that BiggRed do a caliper rebuild kit that was listed as fitting the 5.0 L320 Sport for £40 that included the pistons. I looked up the LR parts catalogue and found that the 5.0 L320 Sport and the L322 use the same rear calipers so I ordered the kit. It arrived next day.
Thankfully when I stripped the old calipers the corrosion that was forming on the side of the piston hadn’t affected the bore of the caliper so a rebuild was very straight forward.
I cleaned the calipers up using a wire brush in the grinder and then used the air line to blow the piston out of the caliper.
I then lubricated the new seals and piston with brake fluid and reassembled with the new dust shield in place.
I then worked the piston in and out with the airline (using a block of wood to stop it coming out too far) and squeezing it back in by hand to make sure it was free to move.
After that, they were given a clean with brake cleaner to remove any grease and then balanced on a broom handle and given a coating of Thunder Grey paint. I gave them 3 coats in the end.
I then refitted them to the car and built them back up.
I tried using a nut and bolt with copper washers to seal the union up whilst the calipers were removed which didn’t work. I also read online that ear plugs work as they swell with the brake fluid but they didn’t work either and the reservoir ended up emptying into the buckets I’d let the flexi’s dangle into.
First up I filled the pressure bleeder with brake fluid and pressured it to 20PSI before opening each rear bleed screw one by one. I got fluid at the wheels but the pedal was awful. I then used the diagnostic machine to bleed the brakes which saw a load of air removed but the pedal wasn’t great still. I then reconnected the pressure bleeder and went around each caliper in sequence twice and that’s now got the brake pedal back to feel perfect. It’s also got nice new brake fluid around the system too as I went through just over 3 litres getting it all bled out properly.
Looking at the colour of what came out it was overdue a change anyway Smile
So, that’s both rear Calipers rebuilt to add to the list of completed jobs now!
All of the parts have arrived to sort the gearbox out now too but I’ve not had time to sort that out.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #680887 21st Dec 2023 2:08pm
Top job, should be sorted for a while now...
Good luck with the box.... Thumbs Up Pete
Post #680889 21st Dec 2023 2:18pm
Great job David “as ever”
David, I put the keys in the blue 322 today after it’s been parked for 3-4 maybe even 6 months and I kid you not, it started first piston up! Popped a ctek on it down the back whilst we’re closed for crimbo… 👍
Post #680907 21st Dec 2023 7:07pm
dhallworth
I decided I’d had enough of the festivities today. Cheryl went to meet her pal and her kids at soft play and she took Matthew with her so I had an afternoon to myself. I decided I’d get the dampers and solenoids swapped out in the valve body on the Range Rover gearbox.
I didn‘t take pictures of the removal of the valve body today as it’s exactly the same as the process above when we proved it was a knackered solenoid causing the issues in the first place.
Once the valve body was removed from the car I swapped out the solenoids before starting with the disassembly of the valve body as the ECU has dowels on it that will help align everything upon reassembly so I thought it would be handy to have them done rather then trying to do more with the valve body loosely assembled.
Once the valve body was on the bench with the ECU removed from it, I loosed and removed all of the bolts that hold the two halves of the valve body together. I grabbed this picture before I started lifting screws out so I knew which holes had screws in them.
Once the valve body is split in half, this is what you see:
You can see the 7 dampers in a row at the front of the valve body in this half.
The dampers were all swapped out next. Here’s the old ones next to the installed new ones.
Whilst it was in bits I took the filter out of the valve body and gave it a quick clean. It was spotless when removed thankfully.
After that was done I got the new intermediate plate out of the box.
I then reassembled everything, reinstalled the valve body in the gearbox, then installed a new genuine ZF sump with a new set of bolts which replaced the original one that was missing when I got the car.
After that I filled the gearbox with oil till it was dripping out of the filter plug and reinstalled the fill plug. I then switched the ignition on and cleared the gearbox adaptions. The car was then started and the gearbox was filled until fluid was coming out of the fill plug again. With the IID tool the temperature of the gearbox oil was observed and when it got to 40 degrees the fill plug was removed once more to set the fluid level properly.
I’ve only driven it a couple of miles since doing it but the only way to tell it’s changing gear at the moment is by listening to the engine revs. The box is silky smooth like a hot knife through butter. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #681280 28th Dec 2023 1:35am
Superspoons
Excellent David - I'll be following that when I do mine in the Spring. Thanks for all the information and parts suppliers. Gavin
1998 Defender 50th Anniversary - GB168 - preparing for sale
Post #681304 28th Dec 2023 12:31pm
dhallworth
Done 90 miles in the car now, most of which has been done on A and B roads to afford the car as many opportunities to change gear as possible. The gear change on it is now silky smooth. Since doing this, I’ve not felt a single change, you can hear the engine note change and you can see the revs change, other then that you can’t tell what the car is up to Smile
Really, really happy with how this one is performing now!
Got a work trip to Cheshire in January that I’m going to use this car for so it’ll be a chance to get some decent miles on it.
Thinking my next job might be to integrate Apple CarPlay into the head unit.
Post #681454 30th Dec 2023 1:12am
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Great news and long may it continue!
Post #681468 30th Dec 2023 11:40am
Daz90
Awesome!
Post #681668 2nd Jan 2024 10:23am
Well done David... I recall those 6HP gearboxes always felt "value for money" whenever serviced... Thumbs Up
Post #681691 2nd Jan 2024 3:12pm
dhallworth
Thanks guys Smile
This one has settled in remarkably well with nothing felt between any gears and nothing when going from D to R and back again which is quite common on the 6HP26.
The 6HP28 in the 5.0 seems to change gear much quicker then the 6HP26 did in the 4.2 as well. I guess this is down to the totally different valve body between the 2 gearboxes.
Overall, I'm really happy with this one now.
MOT is booked for 9th January so lets wait and see how we get on then!
Post #681695 2nd Jan 2024 3:18pm
RRD
Belgium 2012 Range Rover Vogue TDV8 Santorini Black
Just finished reading this thread, very jealous of how handy you are! I've bought an L322 5.0 S/C myself yesterday. The chains are already done on mine, but I think I'm experiencing the same problems with the gearbox as you did.
When I drive at a constant speed of 120km/h (+/- 75 mph) the revs on the dashboard juggle a little bit. I've also experienced a slight hesitation at slow accelerations. It will not always do it, I've experienced this twice now, having driven +/- 300 miles in it so far. Are these the same symptoms you had? '17 Range Rover 5.0 Supercharged AB (Sold)
'16 Range Rover SDv8 AB (Sold)
'15 Range Rover SDv8 Vogue (Sold)
'13 Range Rover SDv8 Vogue (Sold)
'12 Range Rover TDv8 (Sold)
'10 Range Rover 5.0 Supercharged
'03 BMW E39 M5
'01 BMW E46 M3
Post #682190 8th Jan 2024 9:08pm
dhallworth
Mine was hesitating in 3rd gear at around 1500 - 2000rpm when being driven gently. If you gave it more throttle then the hesitation stopped.
My revs were fluctuating by approx 200rpm when sitting on the motorway on cruise control.
You can see it in this video:
https://youtube.com/shorts/GVecayPbJO8?si=ynPV0SNcGJqWj3J5
Looking at your signature, yours is a 2017 5.0 though which means it’ll be the 8 speed gearbox whereas mine is the 6 speed.
Post #682195 8th Jan 2024 10:17pm
RRD
Thanks for the video. I sold my 2017 L405 S/C last year. I'm talking about a 2010 L322 5.0 S/C with the ZF 6 speed gearbox. I'm currently in the process of getting it on the road here in Belgium and will drive more after all of that is sorted. '17 Range Rover 5.0 Supercharged AB (Sold)
'03 BMW E39 M5
'01 BMW E46 M3
Post #682200 8th Jan 2024 10:32pm
dhallworth
Pleased to report that after dropping it off this morning, the RR has sailed through its MOT with no advisories.
Was pretty sure it would pass as I’d given it a good once over but nice to know they’ve not found anything I’d missed!
Intrigued to see the emissions certificate though. Always like to see how cleanly it’s burning fuel.
Post #682244 9th Jan 2024 3:16pm
