Home > Technical (L322) > Battery drain test procedure |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
18th Dec 2023 5:44pm |
camcc Member Since: 01 Oct 2023 Location: Godalming, Surrey Posts: 30 |
The car has only been on the drive with a brand new battery for two days, not driven except for the 30 mile drive I took it on after installing the new battery. The battery reading yesterday afternoon was 12.5V and today 24 hrs later it is 12V and I got another suspension error (which I've cleared again). That's like 50% battery charge in 24 hours...which seems a lot for a 60mA draw. Could my alternator be causing issues? How can I accurately test that? (When I start the car the voltage goes up to 14.x)
18th Dec 2023 5:53pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 654 |
I have just gone through all this myself earlier today, if the car is stationary for 2 or 3 weeks the battery is dead, but this is on my RR 2004 4.4 BMW Engine Petrol V8
18th Dec 2023 6:02pm |
18th Dec 2023 6:23pm |
OK....after a few hours measuring across fuses I am unfortunately no closer to finding the source of my ~60mA drain.
18th Dec 2023 10:20pm |
See pic below. It happens when the battery voltage gets down <12V. I think it's a result of the drain, not the cause but happy to be challenged on that. Also, see previous post above for latest troubleshooting update. Appreciate all your advice so far. |
18th Dec 2023 10:30pm |
18th Dec 2023 10:33pm |
18th Dec 2023 10:35pm |
Code is: U2007-67 (AF) Valve(s) circuit - Algorithm based failure - signal is incorrect after the event . 2005 L322 4.4 AJV8 |
18th Dec 2023 10:43pm |
18th Dec 2023 10:55pm |
Eek, that is a bit above my current skill set!
18th Dec 2023 11:42pm |
19th Dec 2023 10:12am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
Have you tried physically disconnecting the SatNav DVD unit yet? .
19th Dec 2023 6:09pm |
Hi all,
3rd Jan 2024 5:18pm |
