Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Garymcduff1 Member Since: 05 Sep 2023 Location: Wales Posts: 6 |
Thanks again for replying, is the oil drain modification the 2 returns back to the sump from the turbo? If it is mine has already been done. I've cleaned the engine several time but can't find anything whilst at stand still, it only happens when being driven so difficult to locate. |
5th Sep 2023 11:03pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1356 |
The drain mod looks like this:
5th Sep 2023 11:22pm |
Thanks garyrr I'll check mine |
5th Sep 2023 11:24pm |
Trev Grummett Member Since: 06 Jul 2023 Location: Mackay Posts: 1 |
Hey Guys,
20th Sep 2023 11:51am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
I've just bought another 4 BS611 V75 from my local bearing supplier, having become aware that Viton 90 doesn't have the high temperature rating of Viton 75. Cost was $5.50 for the 4. |
20th Sep 2023 12:46pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4241 |
Nice little video
19th Oct 2023 4:44pm |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 157 |
So Yesterday I west to a classic car rally. First blip was the keep fob not working so fixed that. Then got half way to the rally and got low oil warning. Topped up with a litre, let it rest and it didnt register. Topped up with a 2nd litre and it said under filled, fill another 1.5 litres. My heart sank.
3rd Dec 2023 1:48pm |
Ok guys
3rd Dec 2023 5:40pm |
I went looking for mine's very slow coolant leak today with the previously mentioned 18x2.5mm V75 o-rings on hand for the coolant fitting on the oil cooler. It didn't appear to have been leaking but I intended changing the o-ring anyway. However a test fit of the o-ring on the pipe stub revealed that the o-ring was obviously too large.
16th Dec 2023 9:01am |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 183 |
Image 1 looks like your EGR inlet. If you stand in front of the car looking to the rear, it will be on the right of the engine under the doughnut.
25th Dec 2023 1:26pm |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
I`ve got the dreaded oil cooler leak.
10th Jan 2024 12:53pm |
Hi SFM
10th Jan 2024 1:03pm |
Hi Fla
10th Jan 2024 4:35pm |
Hi SFM
10th Jan 2024 7:30pm |
