Home > Technical (L322) > Accidental Fix L322 Deployable Steps |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 398 |
Hi,
16th Jan 2024 9:25pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16188 |
Or simply unplug the motor... Can't move that way |
18th Jan 2024 2:01am |
Hi,
18th Jan 2024 9:42am |
Proftinkerpot Member Since: 23 Dec 2022 Location: County Antrim Posts: 165 |
After posting on this thread 2 days ago, yesterday I noticed that the drivers step was still deployed when I came back to the car. I unlocked and locked again and the step retracted a little then stopped and deployed again. I got in the car and the step didn't retract. I drove home and before I got out I looked out the window and the step had retracted. Opened the door and it deployed. Locked the car and it snagged and deployed again. I can't see anything physically hampering it. When the weather improves I will give the moving parts a good clean and lubricate them with some moly grease.
19th Jan 2024 1:07pm |
Hi,
19th Jan 2024 2:46pm |
Thanks for that advice Andyroo. Definitely will give that a go.
19th Jan 2024 5:35pm |
th3chainrule Member Since: 24 Sep 2022 Location: East Posts: 15 |
What jack do you use on your vehicle? |
19th Jan 2024 7:53pm |
Hi, I use a full size trolley jack @ home, but in the car I keep a bottle jack. Fuji White 2012 4.4 TDV8 Westmiinster |
19th Jan 2024 8:03pm |
Yeah, I have a trolly jack too but im concerned that it wont clear the step if it is deployed. Thinking I need to by a bottle to jack the car if I dont take the steps off like you did. I'm too chicken to jack the car from the under the step with the trolly jack. |
19th Jan 2024 8:41pm |
Hi, I have a bottle jack as well but it wouldn't fit under the sill if you had a punture even in off road mode.
19th Jan 2024 10:05pm |
I lock the steps out or else leave a door ajar and use a trolley jack with one of these big rubber blocks between the jack pad and the jacking point. Rubber blocks like this Amazon one
20th Jan 2024 10:32pm |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 169 |
I wish this accidental fuse fix would work for me! I got my steps working for about a week or two after purchase but then they seized up again. When I took them off the arms had seized and on closer inspection the motor housing had failed and water had gotten into the electrics.
21st Jan 2024 12:35pm |
