Home > Technical (L405) > Air Suspension Not in Customer Mode?? |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 55 |
Just been and had another look. I get a screen with the option to 'enable air suspension' press ok and the next screen says, ''Communication failure. Application failed' |
19th Jan 2024 4:51pm |
Back out there at the crack of dawn and somehow managed to reset it., It would seem that the iCarsoft won't let you go as far as the calibration page then change your mind and go back. I went through the whole process of measuring heights as directed on the tool and at the end it said 'Calibration Unsuccessful' and reset itself. ???Don't understand it but don't care....it's working again and I'm done fiddling...Till the next time. |
20th Jan 2024 3:10pm |
Sachp1993 Member Since: 22 Jan 2024 Location: Bedford Posts: 2 |
How did you do the fix? I need help asap pleaseee |
22nd Jan 2024 5:52am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
If the suspension is in tight tolerance mode then switch off the engine then restart it, but that might not get it out of calibration mode. |
22nd Jan 2024 6:10am |
I think the main problem was low battery voltage. I charged the battery overnight then next day carried on with the calibration procedure. At the end of it it said "Calibration unsuccessful" but then the suspension reset so it either won't let you back out or the battery voltage might well be a factor. I've heard it said that it's a good idea to have the engine running when messing with diagnostics so that the voltage is steady. I'm still confused about calibrating with icarsoft but won't be messing with it again ......till I have to. Sorry for the late reply, hope you got it sorted |
22nd Jan 2024 10:22am |
Ah okay, I still didn't manage to fix the issue yet....
22nd Jan 2024 6:51pm |
Maybe an indie or at least a garage with decent diagnostic equipment would be the way to go. Did the fault just appear or were you having problems with it? |
22nd Jan 2024 8:03pm |
22nd Jan 2024 8:06pm |
