Home > In Car Electronics (L322) > Rear windows "vent mode"? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Have you set your windows? There must be a procedure in the wiki above... Set both of the rears, then see if they both work on vent |
22nd Jan 2024 12:29am |
Lukeybabes Member Since: 17 Jan 2024 Location: Somerset Posts: 15 |
Yeah tried a few times to set them. Both on the switches and with the iid. Still the same. Only the drivers side rear does it |
22nd Jan 2024 12:36am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
is the one that only vents, in child lock mode???? |
22nd Jan 2024 4:09pm |
Yeah only the drivers side does it. Nope not on child lock or anything |
22nd Jan 2024 5:27pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 722 |
Both my rears do this with the first push of their respective buttons (2012 Westie). First time it happened, I thought it was a fault, as my previous 3.6 didn't do this. Now, I think it's great - especially when leaving a pooch in the car. The older I get, the more I realise that people confuse wrinkles for wisdom |
22nd Jan 2024 5:41pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7636 |
I’ve no idea what mine do then, given the above replies. 🤣 Must remember to check.
22nd Jan 2024 5:56pm |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 80 |
Same here as yours JMC, first press on both rears and they go down to vent, then second press all the way down, and it does it regardless of how rear locking is set. 2012 Westminster TDV8 4.4 Indus Silver
22nd Jan 2024 7:46pm |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 148 |
if window is fully opened end long press to close window goes to full close, or just few inches? |
23rd Jan 2024 6:39pm |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 65 |
Like JMC and RichTD6 I have a 2012 Westminster and mine is exactly the same - first 'full' press (as you would to put it all the way down automatically) gets the 'vent' position, second press sends it all the way to the bottom. Same on both sides.
24th Jan 2024 12:27pm |
It fully closes if its all the way open
24th Jan 2024 2:36pm |
i checked mine - i have that in my 2010. If you have not calibrated window, then vent mode can be inactive. |
28th Jan 2024 7:59pm |
I checked and my 2015 405 does this too |
28th Jan 2024 9:18pm |
Confirmed that the correct window regulator is fitted. Not an older style one. So no idea now. |
2nd Feb 2024 6:35pm |
