Home > My Range Rover > My first RR a 2013 Vogue SE |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 260 |
They are a small, by appointment only outfit. Yes, you are right. Our last car, an X5, spewed its gearbox oil early in our ownership. 40k and 5 years later it was ultra reliable and no major issues. Thanks |
31st Jan 2024 2:39pm |
Update. My local village garage gave it a good look over today and only found one or two minor issues. So thats great news, the car appears to have good bones!
1st Feb 2024 4:19pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
If there is oil in the coolant, as the oil cooler is a heat exchanger so you tend to get a leak both ways, make sure they give the coolant a good flush. You may have caught it in time. My oil cooler had warped, so needed replacing. Some folk get away with just changing the seal, but you might as well get a new cooler to be sure.
1st Feb 2024 5:12pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
Happy Days, hopefully! “If it ain’t broke, don’t fix it” -where’s the fun in that? |
1st Feb 2024 5:17pm |
Thanks 👍
2nd Feb 2024 8:27am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 663 |
I take it the supplying dealer has agreed to this, as you’re talking circa £800 to replace the cooler etc. 4x4 local Indy said it’s a 4.5hr job, had mine done in the first year of ownership. Not the easiest of jobs to do by all accounts. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
2nd Feb 2024 9:28am |
Yes, absolutely. I’m not going ahead with anything without their consent in writing. |
2nd Feb 2024 9:33am |
L405 must be practically the same as the L322 for this job…. I’m sure there is a how to somewhere, may be in the Wiki…
2nd Feb 2024 12:51pm |
https://www.fullfatrr.com/forum/topic48745-15.html
2nd Feb 2024 12:53pm |
Thanks. I’m doing it now myself. So i disconnected the battery and the alarm went off! I think the car needs to be unlocked first.
8th Feb 2024 10:28am |
It appears the car needs to be unlocked before disconnecting so it will have to remain unlocked overnight. |
8th Feb 2024 10:46am |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 258 |
Page 18 of the handbook linked to in the Wiki suggests you can just lock the doors with the emergency key blade. It's the US version of the book but I would be surprised if the UK car is any different?
8th Feb 2024 11:55am |
Yes, i have that but thought it only unlocked/locked the drivers door?
9th Feb 2024 9:07am |
No idea, my L322 has big sensible buttons on the doors, but I thought it might be worth a look. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
9th Feb 2024 10:14am |
