Home > Technical (L322) > Strange smoke |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 299 |
Had my car about 18 months now. Work van got stuck in the verge outside so I pulled him out. First, I had it in low range (first time ever) and when I was sat still there was a lot of strange smoke coming from underneath. Switched to high range and pulled him out and the smoke disappeared. Any idea what it was/is? Tym
7th Feb 2024 11:47am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3077 |
could have been the FBH kicking in? |
7th Feb 2024 7:53pm |
To my knowledge, I haven’t got one. Tym
7th Feb 2024 7:54pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7649 |
I think all diesels have one. It might be the extra fob for remote park heat that you haven't got. The FBH exhaust is down near where the passenger side front mudflap is or would go, if that’s the vicinity you had the smoke from.
7th Feb 2024 9:20pm |
Not sure, I just know there are as smoke coming from under the car! Switched to high range and it stopped. Tym
7th Feb 2024 9:22pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4252 |
Maybe the motor for switching ranges was burning out due to lack of use? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th Feb 2024 9:44pm |
It switched range ok. The smoke happened after I’d tried to pull the van out. Switched to high range, continued to pull him out (successfully!) and there was no smoke whilst in high range. Tym
7th Feb 2024 9:46pm |
Keep driving and ignore it
8th Feb 2024 9:38am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 398 |
Hi, might be oil seeping down. I had it intermittantly when I went in reverse it would drip onto the exhaust silencer, fine going forwards, you may have doslodged some in your to & fro stuff.
8th Feb 2024 10:19am |
I didn’t smell anything, just saw the white smoke. Tym
8th Feb 2024 10:33am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2790 |
If it's oudorless it's likley coolant as difficult not to smell smoke in that area as it gets drawn into the cabin from the top of the bonnet. 2012 TDV8 Vogue (L322) |
8th Feb 2024 11:10am |
Yes, agreed, see if you can smell it next time, could be anything from coolant spillage to an insulation short, each has a very distinctive smell.
8th Feb 2024 11:19am |
I suppose I’ll just have to try it again! Tym
8th Feb 2024 11:20am |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 152 |
Don't forget to turn camera on and keep extinguisher close. Just in case |
8th Feb 2024 12:00pm |
