Home > Technical (L322) > Dead in the water L322 TDV8 |
gm0rdi Member Since: 19 Jan 2022 Location: Hawick Posts: 15 |
Greetings!
7th Feb 2024 2:39pm |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 29 |
Try removing the battery lead for a minute or so. Nothing to lose, and You never know it may sort it. |
7th Feb 2024 2:57pm |
I'll give it a bash tomorrow; I did pull Fuse 5 (which in theory should do the same job) and that made no difference. But as you say, it's a zero cost thing and worth a go. |
7th Feb 2024 3:10pm |
Well absolutely it could be. Trouble is I don't know where to find that. I have a question about the KVM - is that the thing that the keys are paired with? I'll need to ponder how I can identify that as a possible cause of the issue. |
7th Feb 2024 3:22pm |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 146 |
Just out of possible interest :
7th Feb 2024 6:29pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 649 |
KVM ( Keyless Vehicle Module )
7th Feb 2024 8:04pm |
Ah ! Cheers for that! |
7th Feb 2024 8:47pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
Have you tried holding the key in the very specific position against the lower panel below the light switch then attempting to start? The owners manual has following instructions and a picture showing the key positioned below the light. The key may need to be moved about a little to get it to work.
7th Feb 2024 8:58pm |
7th Feb 2024 10:19pm |
Greetings - I appreciate the input, but that doesn't change anything (with either of the keys I have).
7th Feb 2024 10:45pm |
If you have "Smart Key Not Found" message, then at the very least you should try placing your key just below the light as per instructions shown above, not sure why you would not want to do that in your quest to troubleshoot the issue - please don't shoot the messenger |
7th Feb 2024 11:02pm |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 134 |
Is there, by any chance a Construction crane with remote control nearby?
9th Feb 2024 9:43am |
Greetings.
9th Feb 2024 10:50am |
drphilgarner Member Since: 20 Sep 2022 Location: Lancaster Posts: 32 |
Let us know how you get on, this is an interesting one! 2011 4.4 TDV8 Vogue |
13th Feb 2024 10:09am |
