Home > Maintenance & Mods (L322) > Warning Triangle installation: Wiring in the way
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Hi Everyone,
I bought the LR Warning Triangle to install in my '09 L322. It should be a super simple installation but for one issue. There's some wiring that's in the way.
If you look in these pictures, I've put a red square around the bits that are in the way.
Before I start snipping zip ties and trying to reroute some of these wires, has anyone else run into this issue? If so, how did you reposition these bundles of wires?
Thanks in advance!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #574215 26th Nov 2020 7:42pm
put the triangle in the wheel well.... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #574216 26th Nov 2020 7:44pm
lschwarcz
Yea, it'll fit there but it's supposed to go in this side pocket. And my OCD* demands that's where I put it! Smile
I think I can gently reposition those wire bundles a bit and then secure them again with some fresh zip ties. I'm pretty busy today (Thanksgiving holiday here in the USA) but I'll try to tackle this one over the weekend.
Thanks!
Larry.
* My OCD is actually pretty mild. I have a friend who has, "CDO." It's exactly the same as OCD but in the correct alphabetical order. Rolling with laughter 2009 Range Rover L322 Autobiography
Bournville/Ivory
Post #574217 26th Nov 2020 7:51pm
Mine went in there no problem....
Put it in the hole at the bottom and shut the flap... There is nothing that can't be fixed with a hammer😜😜
Post #574220 26th Nov 2020 7:57pm
lschwarcz
When I try that the triangle is pressing against those wire bundles with a bit of pressure. These cars are famous enough for their electrical issues. Shocked
I'd rather see if I can get it to fit there without pressing on the wiring.
Thanks!
Bournville/Ivory
Post #574221 26th Nov 2020 8:03pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
I hear you about the OCD...
Hope these will help.
The triangle fits at the recessed base while it's mounting/ holder is secured with a plastic pin in the hole at the top. (See arrows) I believe the wires won't be in the way like this.
Post #574267 27th Nov 2020 10:33am
lschwarcz
You would think so, but that's not the case. With the top holder in the correct location those wires do interfere with the triangle.
I'll try carefully repositioning the wire bundles (no tugging, pulling or additional tension on them!) to see if I can get it to fit.
Thanks!
Bournville/Ivory
Post #574321 27th Nov 2020 5:20pm
vs322
Best of luck!
Post #574330 27th Nov 2020 6:02pm
flashheart59
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Galway Green
Trying to fit a genuine triangle myself and having the exact same problem - was rerouting the cabling the answer/possible? Thanks in advance.
Post #684671 3rd Feb 2024 1:37pm
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
My previous car, a 2005 TD6, had a slightly different top mounting bracket to the one in my current 2012 Westminster. The TD6 Bracket was all plastic and clipped flush around the triangle. The Westie definitely appears to have more cabling in that area, but the bracket is slightly angled and secures the triangle with a rubber strap which allows it to fit over the extra wiring behind. Maybe you need the later fitting bracket and strap too?
Rich 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #684682 3rd Feb 2024 7:02pm
flashheart59
Thanks Rich, think you’ve nailed it. I’ll try to find the newer bracket, a picture would be incredibly helpful if you were able? Thumbs Up
Post #684731 4th Feb 2024 5:25pm
RichTD6
I will do my best at the weekend when it’s light. Bear with me though as I’m not very savvy with technology and uploading a photo will be a new challenge! Laughing
Post #684994 7th Feb 2024 8:52pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I think I remember having a similar problem when I added 1 to our car a few months after purchase.
All I did though was apply steady pressure on the wiring loom until the warning triangle would fit.
I was probably lucky that I was doing it on a relatively warm UK day, so not that much effort required.
If you're trying it on a cold day, I'd suggesting adding some heat via a hairdryer to gain some flexibility. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #685018 7th Feb 2024 10:32pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Not really very helpful to the OP......
Many of us like things to be "correct" - I had the same issue and found that I just had to "tease" the wiring looms back a little with a couple of after market cable ties.
Post #685022 7th Feb 2024 10:45pm
RichTD6
Sorry it’s taken me a while to get some photos but I have managed today.
The part number appears to be LR011186 - Warning triangle bracket 2010-2012
Hope this helps.
Post #685871 17th Feb 2024 5:45pm
