Home > Technical (L322) > Is it worth doing an egr deleted at 100k+? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Yes. Physical and electronic delete needed which I think they’re suggesting Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th Feb 2024 11:50am |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 247 |
i would go for it .......that is a very good price .if i was close i would take mine in to get done 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
17th Feb 2024 2:57pm |
Cinderrella Member Since: 03 Jan 2024 Location: Leicester Posts: 42 |
Thanks guys, I spoke to them and they don't put blanking plates on... Just ag EGR delete. Is it still worth doing? |
17th Feb 2024 5:29pm |
if it was me i would….still think it is a good price 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather |
17th Feb 2024 5:35pm |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 148 |
The EGR system is there for various reasons.
17th Feb 2024 10:33pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1102 |
Engaging in illegal EGR removal or other emissions control system tampering in the UK can result in various penalties, including:
17th Feb 2024 11:19pm |
ttrw2 Member Since: 27 Dec 2015 Location: Oxfordshire Posts: 38 |
I blanked the EGR on mine at ~150k miles. Straight away it idled better, the tip-in response improved (when you initially open the throttle) and MPG improved by a small amount.
18th Feb 2024 8:03am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2734 |
Irrespective of the legality or performance changes ( good or bad) the EGR valves on the 3.6 engine have a nasty habit of failing and parts being sucked into the turbo and possibly the engine so for this reason alone it probably worth doing. I'd physicaly blank them as these older EGR valves have been known ( on other cars at least) to stick open so a software delete alone won't help you. Blanking kits are cheap to buy and if you have a GAP IID tool you can buy a software update to do the software delet yourself. 2012 TDV8 Vogue (L322) |
18th Feb 2024 11:27am |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 668 |
+1 on Jaygee's comments.
18th Feb 2024 5:03pm |
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 49 |
Just a thought!!
19th Feb 2024 11:07am |
Not on a 3.6. Thinks that's required on the 4.4TDv8 Paul,
19th Feb 2024 11:21am |
No DPF on the 3.6 2012 TDV8 Vogue (L322) |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
Just out of interest, do these go through the MOT OK? “If it ain’t broke, don’t fix it” -where’s the fun in that? |
19th Feb 2024 12:37pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
Yes they do Got - 2017 SDV8 Autobiography in Loire Blue
19th Feb 2024 2:16pm |
