Home > Technical (L405) > Vibration concern - is it me? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3696 |
Have you got noise reduction tyres ? If there has been a puncture the tyre depot removes part of the foam and sticks it back - this can come loose causing vibration, or a buckled wheel, lost wheel weight or a drive shaft bearing on the way out. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
19th Feb 2024 9:38pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1343 |
If it's happening at idle then probably not tyres. Maybe engine mounts? Only Range Rovers since 1988 |
19th Feb 2024 10:10pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
Agreed. Could be the active engine mounts. Kev
19th Feb 2024 10:28pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
#3
19th Feb 2024 10:44pm |
Of course they can be tested. They are vacuum controlled so you can apply a vacuum and see if it holds.
19th Feb 2024 10:55pm |
Or here...
19th Feb 2024 11:01pm |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 358 |
Many thanks for your replies
20th Feb 2024 9:07am |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 161 |
Related possibly but I found my L322 to be quite vibration-y at idle and generally unrefined. (4.4tdv8)
21st Feb 2024 5:26pm |
