Home > In Car Electronics (L405) > SOS limited functionality - battery replaced but not fixed |
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 72 |
Taking the trim panel off is a pain as there are two bolts at the top of the trim panel and to get to those you need to remove the center screen surround and the one on the right hand side of the steering wheel.
1st Mar 2024 10:58am |
Captain_67 Member Since: 26 Feb 2024 Location: Ellesmere Posts: 14 |
Thank you for the reply you have confirmed my suspicions and it looks like it’s a slow and steady job with no short cuts. I guess LR needed to make the TCU difficult to access. Did you need to have the TCU reprogrammed after replacing the battery and if so is this a main dealer job
1st Mar 2024 11:24am |
I still have the error code so a trip to the dealer is needed to get it reset with an IDD 2016 AB SDV8 Barolo black |
1st Mar 2024 11:38am |
4RRS Member Since: 13 Apr 2022 Location: Stafford Posts: 119 |
Not sure IID can do it, I've never seen the option on mine, but SDD will do upto pre facelift MY 2017, then it's pathfinder or Topix cloud. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
1st Mar 2024 12:15pm |
is SDD something you can buy for a sensible price ? 2016 AB SDV8 Barolo black |
1st Mar 2024 12:33pm |
It's a £3K+ yearly subscription for the genuine item, cracked copies are available which will do the job perfectly, you will need a VCI and a laptop however. If you have a laptop maybe look at :-
1st Mar 2024 12:37pm |
Thanks.
1st Mar 2024 12:51pm |
It's simple to install the legit version which you can download for free from topix, if you don't have a topix subscription you will need to crack it, which is a little harder. Dpending how long you want to play with it, you maybe just better paying a little more and having the operating system and cracked programme pre-installed on the hard drive and then just swap it out with your laptop hard drive.
1st Mar 2024 1:49pm |
Just for information
4th Mar 2024 2:56pm |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 209 |
Latest version of the IIDTool software has the TCU battery test function (at least when connected to a 2018 vehicle, so should be ok for earlier ones). I've not had cause to use it so can't verify it though. |
4th Mar 2024 3:44pm |
Whilst my car was in for an MOT at the main dealer today they cleared the fault for me free of charge.
5th Mar 2024 1:51pm |
