Home > My Range Rover > My first RR a 2013 Vogue SE |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 180 |
Perhaps a stupid question but when you say adjust - you mean the two torx screws and adjust up/down? |
4th Mar 2024 9:32pm |
Yeah I saw that also, I will take a look at the lock at the weekend - thanks |
5th Mar 2024 7:33pm |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 328 |
Interesting, I have just contacted RCV for some service work, and they suggested leaving the gearbox alone unless it has issues? They said in their experience changing the oil/filter can cause issues.
7th Mar 2024 10:29am |
Oil/filter is part of the maintenance schedule for the L405 (and L322), unlike all the sealed for life nonsense that keeps being perpetuated online - so that is nonsense, quite frankly. |
7th Mar 2024 3:45pm |
I’ve removed the oe steps in preparation for some aluminium ones.
10th Mar 2024 9:32pm |
Ok, I still appear to have a slow coolant leak which I’m trying to locate. In the meantime I keep an eye on the level and top up as necessary. Is this the correct coolant? There’s so much choice these days 😳
16th Mar 2024 11:24am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8147 |
Some pictures on this thread of a common water pipe leak if you have the rear heater...
16th Mar 2024 12:52pm |
PLC Member Since: 23 May 2022 Location: Stafford Posts: 18 |
Have you tried pressurising the coolant system to help locate the leak |
16th Mar 2024 2:15pm |
Thanks gents. Mine is leaking down the back of the engine and bellhousing so unlikely to be the rear heater. I’m trying the dye method at the moment to locate the leak. Failing that pressure testing is a good call 👍 |
16th Mar 2024 4:30pm |
Today I finally got around to removing my floppy armrest. Anyone know how it comes apart?
28th Mar 2024 5:12pm |
I found a new armrest (OE) in Lithuania so that is on order.
1st Apr 2024 2:02pm |
I’m not sure I prefer them over standard black, but the wife does 🤷♂️ in fact I prefer no steps. |
1st Apr 2024 2:03pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3127 |
REf coolant leak, it may be EGr cooler? |
1st Apr 2024 2:53pm |
Yes, I hope not but you could be right. I’ve booked it in with an indie for a couple of jobs and I’ve asked them to diagnose the leak. It’s used perhaps 1/2 litre in 200 miles. |
2nd Apr 2024 12:34pm |
