Home > Maintenance & Mods (L322) > Brake pedal issue |
Mart67 Member Since: 26 Apr 2016 Location: West midlands Posts: 45 |
Can somebody confirm that the vacuum pump ( small cylinder attached to the side of the l/h inner chassis leg,as you look at the engine that the vacuum line runs to) should be running constantly?? As mine is doing nothing?? |
29th Jun 2017 12:12pm |
Has nobody out there had any issues with servo or vacuum failure? Looking on the net it appears common on the RR sport? These I believe used the same setup as the 05/06 l323 fitted with brembo brakes? I believe there was a recall to replace both servo and master cylinder?? |
2nd Jul 2017 1:07am |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
Sounds like a Servo/vacuum issue, unfortunately I have no additional knowledge to assist, sorry Regards
2nd Jul 2017 8:07am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
I might be wrong but does the petrol engine have a vacuum pump, petrol engines usually have enough vacuum available to operate the brakes. Vacuum pumps are fitted to diesel engines due to lack of sufficient vacuum and then are fitted directly to the engine block to receive a drive mechanism.
2nd Jul 2017 9:33am |
Hi there, the pump fitted is 100% only connected the vacuum pipe from the inlet to the servo. I suspect it is a vacuum pump as they are listed on the net for sale as vacuum pumps fitted to late model sc l322 and 405 sport.
2nd Jul 2017 2:07pm |
Had a look through the manual and it does seem no vacuum pump is fitted to the earlier petrol engines, only to the diesel versions. On the diesel the vacuum pump is fitted high up on the front end of the engine block. What the item you describe is I'm not sure, nothing is shown in the manual.
2nd Jul 2017 3:04pm |
Hi there, I have attached a pic of the pump,fluid hasn't moved in the reservoir and all calipers, lines etc appear dry? The pedal when pressed works fine and slows the car as it normally would, its just the last amount of travel that would actually stop the car feels vague and you really gave to apply force? There is vacuum present at the servo. The discs and pads are genuine brembo, it maybe feels the same as a cheap set of pads that have no bite? It's strange and hard to diagnose without changing things one at a time. I'm going to get the pads out later and see if they appear glassed. It's strange there's been a
2nd Jul 2017 5:02pm |
Well I can honestly say I have no idea what that pump is.
2nd Jul 2017 6:34pm |
Have checked vacuum pump and it is working if I connect it straight to 12v. I need to find out if this should run all the time as there is no voltage at the plug with the engine running and in drive?? Took it out for a good test run and managed to get the engine management light on under heavy breaking? I will get the Gap tool on it tomorrow but I'm wondering if it's got a vacuum leak that I have missed or havnt found yet?? |
2nd Jul 2017 10:28pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Has anybody got a definitive answer as to when the vacuum pump should run? I'm getting a lack of power assistance until manifold vacuum kicks in. Think I may also have defective non return valve on vacuum pipe. Previous cars:
24th Feb 2024 2:19pm |
Non return valves OK. Still don't know when the vacuum pump is supposed to work. I may be getting used to the wife's JCW hatch stopping on a sixpence, it's less than half the weight of mine and the front discs are enormous. Previous cars:
6th Mar 2024 1:10pm |
Found this to be interesting. I'm guessing that the one on my SC is the controlled variant.
7th Mar 2024 9:06pm |
