Home > Maintenance & Mods (L322) > a Wheel alignment and what to do L322 |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 174 |
Best to get a four wheel alignment done at somewhere that uses Hunter equipment. |
9th Mar 2024 2:27pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 252 |
I agree with the recommendation for a Hunter alignment. I guess you may have to travel a fair way to find one in Ireland though.
9th Mar 2024 9:42pm |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 666 |
3 degrees is probably less than 1 spline on the steering column.
11th Mar 2024 12:20am |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 152 |
Hi all
11th Mar 2024 11:10am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2662 |
Well worth making sure all suspension joints, bushes etc are in good condition before you do a wheel alignment as worn bushes will not keep the same alignment during dynamic conditions ( driving) as during static conditions ( alignments) and you can end up going round in circles esp with regards to off center steering wheels or pulling to one side. 2012 TDV8 Vogue (L322) |
11th Mar 2024 11:29am |
Sorry double post 2012 TDV8 Vogue (L322) |
11th Mar 2024 11:30am |
Hi Jaydee
11th Mar 2024 11:55am |
Any good 4 wheel alignment place will do. Hunter are good but they are not the only ones. What tyres do you have? Brake pulsing can be a sticky piston on the front caliper which can warp a disk.
11th Mar 2024 12:54pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3194 |
If everything else is fine and the steering wheel is out of aliggnment, which can be annoying, you can reposition it. The initial stage can be a bit of a fiddle to release the mechanism but otherwise straightforward.
11th Mar 2024 1:34pm |
@ Jaydee
11th Mar 2024 1:45pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 338 |
Hi, I'd be wary about just realigning the steering wheel because if it's not been set up correctly wrt the rack itself then the rack will not be central.
11th Mar 2024 1:49pm |
Hi Andy,
11th Mar 2024 2:11pm |
Be sure to check that it is put in tight tolerance mode if you go for a Hunter alignment. John
11th Mar 2024 6:24pm |
Weegie
12th Mar 2024 10:21am |
