Home > Technical (L405) > Difference on the 5 litre petrol engines
Bluebird
Wales 2016 Range Rover Autobiography SDV8 Santorini Black
I wonder if someone can give me the difference between a 5L V8 SV autobiography Dynamic and a 5L V8 autobiography ? I see that the SV has more power but I don’t think it is much. Which one would you go for ? Thanks
Post #688528 20th Mar 2024 7:18pm
D3Jon
Hi,
I had a moment to spare, so after a few internet searches as well as a look on Autotrader, it would seem the Dynamic get's around another 40Hp (PS) over the non-Dynamic.
It depends a little on what year you're looking at, but a typical 2018 car is 525PS vs 565PS. Earlier cars are 510PS vs 550PS. There are other power figures about, they seemed to have to changed slightly some years, but generally it's around 40Hp difference. Let's face it... anything over 500Hp is more than adequate though! Smile
Don't know how the power lift on the Dynamic is achieved, but would assume it's done electronically in the ECU map, or could be a slightly smaller pulley is utilised on the Supercharger in combination with ECU changes.
I think the main difference I spotted between the Dynamic and non-Dynamic spec is in the styling details as well as the Dynamic having stiffer and lower suspension (it sits 8mm lower).
I found this 2017 press release which gives some insight:
https://media.landrover.com/news/2017/01/r...hy-dynamic
Hope this helps a little.
For what it's worth, if I was faced with this envious choice, I'd be going for the non-Dynamic spec. Every 8mm above the roof lines of other cars on a busy road count! Plus, my days of hurtling down B roads are long gone! Smile
Jon 1992 RR Classic 3.9 efi Vogue
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #688532 20th Mar 2024 8:43pm
Bluebird
Thanks Jon , plenty of information you supplied - appreciated. Tim
Post #688551 20th Mar 2024 11:43pm
I'd go SVA .... Wink Mike - MPx
Post #688553 21st Mar 2024 12:16am
Rex the RR
Just been through the same scenario. Hell bent on getting an sv. Ended up buying a p525 ab. Wanted a cream interior and blue exterior but the sv seats are all black trimmed, not a good look.
Post #688562 21st Mar 2024 1:43am
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I would go for the one I could afford with the best service history, then spend $2,000 on a remap from www.velocityap.com and have 605hp.
The engines are the same. The difference is software. Dan. πŸ‡¨πŸ‡¦ 2013 L405 5.0 SCV8
Post #688617 21st Mar 2024 3:25pm
Bluebird
Thanks for info all. As I am trying to avoid too many oil changes - I should look into if there is more service requirements for the SC.
Post #688682 22nd Mar 2024 8:46am
JLR oil change schedule has been the same on all the petrol engines I've had right from the BMW era. Once a year or 16k miles whichever comes sooner. Some prefer to do it more often, but that's not the official schedule. Its not like the oil burners with dilution issues etc. I no longer do the miles, but the car tells me when it wants to see Craig at the beginning of the year.
The black or two tone black and light interior were the std interior colours for SVAs, I have the light panels on mine. But I have seen others eg a Tan one in a green car; and a light one in a blue car but it was probably a horrendously priced option when new. As with the other models Black on Black seems to be the most common and least desirable from my perspective, but clearly most prefer it since that is how most of them are spec'd.
 Mike - MPx
Post #688688 22nd Mar 2024 10:39am
Bluebird
Thanks Mike for the information. In error when I bought the diesel RR I never thought their would be issues with short journeys as this never happened with my previous bmw. I think it was miss selling as the dealer knew I was retired and going to mostly short journeys. So that why I will try to ask questions on this great forum, before buying.
Post #688707 22nd Mar 2024 12:20pm
D3Jon
I've been monitoring soot build up in the DPF of our 2.0L XC90 and it rises *far* faster than it ever did in our 4.4TDV8. It can go up 6% in 14 miles of country road driving (our school run), which is a staggering amount. Luckily it also does a 120 mile return motorway run once a week when the wife goes into the office.
I never really gave short journeys a thought when we had our L322 4.4TDV8. It happily did the 7 mile school run and back twice a day with hardly any noticeable soot build up (monitored with my GAP IID).
I think the larger diesel engines are somewhat unstressed in comparison, and don't produce as much soot / smoke (pre-DPF) as say our 2.0L engined XC90 does. I'd conclude from monitoring soot build on both cars that the TDV8 is nowhere near as bad for incomplete active DPF regens & oil dilution as a typical smaller engined vehicle.
NB - Not sure if the DPF volume has anything to do with this, but I suspect it's just that the TDV8 with 313hp doesn't have to boost and fuel as much as a 2.0 does producing 235Hp!
Post #688717 22nd Mar 2024 1:15pm
D3Jon
MPx wrote:
That's a gorgeous interior Very Happy
Post #688718 22nd Mar 2024 1:16pm
CS
If you are almost only doing short journeys might the P400 PHEV be suitable? Have a look at the Harry's Garage videos on that 405, which seemed to work well, and also economically for him (he does have his own charger which will make a big difference). It is what JLR recommend for people doing mainly short journeys, see the "which is right for you" guide on the LR UK website.
If you prefer the 5.0SC then I have not found 'only' 510 as opposed to 525 or 550/565 etc to be inadequate, in some situations more power can be inconvenient e.g. pulling away from a poorly surfaced steep hill junction, the traction control can intrude. Beyond that it is a case of driving the different possibilities and seeing what you prefer. Only Range Rovers since 1988
Post #688720 22nd Mar 2024 1:23pm
Bluebird
Thanks for information. Electric charging cars are a mystery to me, but i like Harry YouTube videos and will have a look again.
Post #688723 22nd Mar 2024 1:28pm
Bora20
Oil change/service $350 CAD
New engine $25,000+ CAD
Why are you buying a Range Rover? It is going to require maintenance. Much more than you think. Oil changes are the cheapest thing.
I had three door latches go bad. $800 CAD, each.
Alternator went bad due to RH valve cover leak into it, $5,000 CAD.
Rear main seal, $1,500 CAD.
Brakes at all four corners with my labour, $1,500 CAD.
Engine mounts with my labour, $600 CAD.
Buy the best warranty you can or buy something else. Dan. πŸ‡¨πŸ‡¦ 2013 L405 5.0 SCV8
Post #688728 22nd Mar 2024 4:51pm
Bluebird
Thanks I only buy from a main dealer as I want the comfort of a Land Rover full warranty.
Post #688729 22nd Mar 2024 5:00pm
