Home > Technical (L322) > Dead radio
Elliott_4.2_2005
Dead radio
Hi i have seen a few threads but none with my exact problem, basically i had the car in for welding work and the battery went dead on the car. To be fair the guy charged it up and got the car into a garage to clear the faults that came up. Problem is my radio screen is totally dead and it won’t turn on wven if i pish the power buttom the screen is just dead. Does anyone know what i should check for?
Thanks in advance
Post #688659 21st Mar 2024 9:19pm
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Try a reset - remove the battery and then connect +ve to -ve on the car. Give it 5 mins or so after you’ve disconnected the battery before you do it.
Post #688666 21st Mar 2024 10:43pm
Elliott_4.2_2005
Thanks, i will give that ago, hopefully that will do the trick!
Post #688667 21st Mar 2024 10:47pm
