Home > Maintenance & Mods (L405) > Oil extraction pumps and pipe lengths |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1104 |
I am very happy with the Draper 10L if you can afford it then you wont be disappointed.
27th Mar 2024 5:49pm |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 122 |
Yeah that is what has been playing on mind. I think the 4.4 oil capacity is 9.4 Litres? And I would expect a little more to come out as well due to the dilution so that is why I was thinking 9l wont quite cut it if I dont want to be having to empty the pump as I go along. Is the Draper one marked with measurements down the side? And how is it for pipe length? |
27th Mar 2024 5:53pm |
Yes it has measurements down the side sticky paper lol Good length of pipe included see pic at its max
27th Mar 2024 6:34pm |
Certainly looks plenty long enough, thanks for the pic |
27th Mar 2024 6:36pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 387 |
Hi,
27th Mar 2024 6:39pm |
What diameter is the extra tubing? is it 10mm that would be required? |
27th Mar 2024 6:41pm |
Hi, can't remember the diameter of the pipe, it's not very thick, just measure the tube with vernier and buy tube that's a little too small. Engine & oil will be warm / semi hot (remember this is plastic we're talking about) so you need to make it very snug or the tube will just soften and either leak or fall off when the vacuum lessens.
27th Mar 2024 6:46pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3689 |
Mine has had a good life, over 7 years, but I would recommend fully, but a suggestion that you get a permanent marker pen and mark up the tank, because the plastic strip soon becomes detached.
27th Mar 2024 6:53pm |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 95 |
I bought a Sealey S01168 Vacuum Extractor that has 9 Litre capacity so can almost do a RR sump in one go. The good thing about the air compressor run extractor over the manual one is you can walk away. It'll cut off if it fills up but I always time the first 2l out and come back 3 times later to drain 7 to 8l of waste oil. It can then be left to do its thing to finish up pulling the remainder.
27th Mar 2024 9:19pm |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 260 |
I use this 9L version (a lot of them appear to be rebranded versions of this) and very happy with it at £50, but the tube is too short.
27th Mar 2024 11:11pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
I use this one:
28th Mar 2024 12:44am |
