Home > Technical (L322) > Judder and then oil lamp warning! |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 154 |
Hi, wondering if anyone can help with the following :
3rd Apr 2024 5:56pm |
Thanks for that, yes it was the oil pressure warning light that came on when I parked up yesterday. Will be checking the car out later this morning when I have time. Seems to be a bit of a coincidence I changed the oil a few days ago and all of a sudden this problem has arisen. Hopefully it’s nothing more serious than the sump plugs are leaking ! |
4th Apr 2024 5:53am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 663 |
Correct oil filter? Fitted correctly? Just thinkin out loud that’s all🤭 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
4th Apr 2024 7:29am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1126 |
I don't know whether the oil filter housing on 3.6 is the same as the 4.4, but if you've just changed your filter try removing the filter and have a look in the housing to see if the drain back valve is still on it's post. |
4th Apr 2024 7:30am |
Thanks for the replies, I’ve just checked the airbox and no sign of any oil. I’m about to check the intercooler pipes but noticed the jubilee clips aren’t opening so that’s the next problem to work around when I’ve had a cuppa.
4th Apr 2024 8:41am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2738 |
If the engine / turbo's have ingested 5L of oil I think you would have noticed the smoke cloud behind you. 2012 TDV8 Vogue (L322) |
4th Apr 2024 8:59am |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 258 |
Halfway up the dipstick does not mean the engine oil level is half of its total capacity, so please don't add 5L of oil to bring it up. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
4th Apr 2024 9:51am |
I think I’ve found the problem, took out the oil filter and I’m afraid I’ve been an idiot ! The oil filter piece at the bottom that sticks out is bent, I haven’t seated the filter correctly and compressed it ! The filter wasn’t dripping in oil as I would have expected but oil had been through it.
4th Apr 2024 9:55am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
This means that the juddering could have been a bearing grabbing due to insufficient oil. Hence the sump should be removed to check and probably replace all the bearings and hopefully the crank journals are OK. |
4th Apr 2024 10:08am |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 260 |
Where has all the oil gone? Any shiny fragments in the filter?
4th Apr 2024 12:45pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2985 |
The difference between max and min on the dipstick is normally around a litre. It should tell you in the handbook to be sure.
4th Apr 2024 1:40pm |
Thanks and fingers crossed youre right David, no shiny bits in the filter I'm glad to say. Will be renewing the filter and topping up the oil on Saturday and take it from there. There was some oil inside the turbo intercooler pipes as seen on the blue rubber glove photo but nothing excessive and had to wipe my fingers all around to pick up what is showing in the photo. |
4th Apr 2024 2:03pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1102 |
Also there wont be any shiny bits in the filter if the oil has bypassed the filter. Safer to drain the oil out completely and inspect, then decide your next move. As GraemeS says, juddering could easily be the start of bearing damage. 2018 SE SDV8 4.4 Byron Blue |
4th Apr 2024 3:11pm |
I agree, and meant to add that too - drain the oil.
4th Apr 2024 4:07pm |
