Home > Technical (L322) > Speedo not working, no ABS, DSC....
mjdronfield
Just collected the car (will try and forget the £602.20 bill) complete new driveshaft and ABS sensor on the rear near side fitted.
The ring came adrift from the driveshaft apparently.
The warranty company will not honour the claim as they say the ABS ring is not part of the drive shaft. Paperwork clearly states driveshaft is covered. You cannot buy the ring seperately to the driveshaft.
They won't cover the ABS sensor, even though its also listed as being covered, as it was damaged by the ring. Which I understand.
They argued with the garage owner. I will speak to them tomorrow and seek to pursue.
Peachy !! Rolling Eyes 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #212486 26th Sep 2013 6:42pm
Who is the Warranty Company?
Post #212487 26th Sep 2013 6:47pm
mjdronfield
auto prtect.
Been very good so far........
instrument cluster pixel fix
Aux fuel pump
Viscous Fan
Rear passenger door latch 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #212492 26th Sep 2013 7:00pm
I would push that claim as far as you can go if the only solution was replacement of the Driveshaft.
Post #212495 26th Sep 2013 7:02pm
mjdronfield
To help others who may have this issue, the abs reluctor ring, as its known, that you can't buy separate to the driveshaft, is available here, separately ;
http://www.reluctorrings.com/cars/landrover
Rolling Eyes
Just my luck....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #212976 29th Sep 2013 9:17am
Meerbusch
Could be the reluctor ring from BMW E36 rear, because of 48 holes and 93,9 mm ???
http://www.ebay.co.uk/itm/BMW-3-SERIES-ABS...56530b03b2 TDV8 4.4 from 2012, 278.000km like new + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #320931 2nd Apr 2015 9:09am
mjdronfield
That looks good.
I am sure there are alternative ways of fixing the issues other than a complete driveshaft.
I suppose as these cars age, such issues will become more widespread.
No issues with the other corners so far..... Touch wood and all that.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #320998 2nd Apr 2015 5:37pm
pcourtney
Another supplier for ABS Reluctor rings ( they have both rear and fronts, but I can't see any difference)
They are really well made and only £13.49 each ( best to buy a pair - one for each side of the driveshaft), the speedo is fed from the rear left ABS signal, and the Reluctor ring on the rear left needs to be in good working order, after 20 years probably best to replace the rears at least Smile
https://www.ukpartsdirect.com/land-rover-r...at-v4.html
Post #690253 8th Apr 2024 4:56pm
