Home > Technical (L322) > Whining noise from the transfer case |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
"....and stops only after the engine is turned off"
8th Apr 2024 6:14pm |
przemi Member Since: 10 Feb 2023 Location: Cologne Posts: 11 |
Now that you ask…strange - it is actually most noticeable when the car is standing (e.g. at traffic lights), cause while driving above 30 mph it is covered by other driving noise. |
8th Apr 2024 7:31pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2985 |
If it’s happening when the car is stationary then it’s not the transfer box that’s causing it.
8th Apr 2024 10:24pm |
ok, I see your point regarding the transfer case - it does not move when in neutral. But I also don´t think its the idler pulley - the noise is not as hearable from the motor bay as it is near to the gear box underneath the car (or even close to the front wheels). It would rather get louder in the motorbay if it would be one of the pulley or the alternator, wouldn´t it? |
9th Apr 2024 8:07am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1343 |
Have you tried moving between high and low ratio a few times in case something that did not disengage fully the first time then does so? Only Range Rovers since 1988 |
9th Apr 2024 2:38pm |
@CS: actually I haven´t but considering what dhallworth wrote: the transfer case should be quiet when stationary - otherwise the driveshaft would also be moving towards the wheels - so the clutch in the gearbox already disconnects the movement towards transfer case, I guess. So now I´m looking for anything that revs always when the engine is on, independent of the movement of the car and is located somewhere near the gearbox and is somehow dependent on the temperature (as it does not whine while still cold). tricky... |
9th Apr 2024 3:04pm |
