Home > Technical (L322) > Is this FBH remote correct?
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
I bought a used remote that was from a 2012 car, mine is a Dec 2011.
The fbh works from the dash timer in the cold weather.
I bought this remote
And the heater is a T91R
I cannot pair this remote, all I get is the light flashing.
Would the warm current temperature affect this or is the remote incorrect?
Thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690518 13th Apr 2024 3:42pm
mjdronfield
That’s the same remote as mine came with. Can’t check receiver currently. There are full Webasto instructions in the Wiki that might help if you haven’t seen them.
https://www.fullfatrr.com/gallery/albums/u...rt-t91.pdf 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #690523 13th Apr 2024 5:15pm
Buellie
Thanks I have read those but still no joy.
Going to change the remote battery first. Does anyone know the battery type I can’t read mine Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690525 13th Apr 2024 5:34pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #690528 13th Apr 2024 6:37pm
Buellie
Many thanks for that Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690534 13th Apr 2024 7:39pm
DrRob
Defo try a new battery. The instruction book actually shows you how to test if the current battery is dead Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #690551 13th Apr 2024 9:18pm
darrenm
My 2010 uses a t 91 remote ( has a t91 receiver ) but my wife’s 2011 uses the t91r and has a t91r receiver so you have the incorrect remote unless the receiver has been changed
Post #690559 13th Apr 2024 11:00pm
Buellie
So my remote is a T91 but the receiver is a T91R if I have understood your post.
How is the T91R remote different visually? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690560 14th Apr 2024 5:54am
Buellie
Just to wrap this up, I changed the battery for a new one and it paired straight away after pulling the plug out of the receiver unit.
So the issue was the battery. The remote was showing a flashing light with the old battery when pressing the buttons but not enough power obviously.
So all good now, thanks for the help. Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #690593 14th Apr 2024 4:27pm
mjdronfield
Nice one. It will just vent the hot air out now the weather is warmer though.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #690594 14th Apr 2024 4:30pm
