Home > Technical (L322) > Ambient Air Temperature Sensor
Simon_CSK
United Kingdom 2008 Range Rover Vogue TDV8 Adriatic Blue
I have the guage in the car reading -40C which I have been able to determine is the failure of the above sensor.
Having done some research I am to beleive that it sits behind the main grille at the front and I set about opening up the front to replace it only to find it gone. No wiring nothing.
Can anyone help me find the wiring scource for this? Photos would help. Thanks Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #544347 18th Feb 2020 8:58pm
WB
Can't seem to find the diagram on new.lrcat.com but on the video above just after the 2 minute mark he points out the sensor.
Post #544358 18th Feb 2020 9:35pm
Simon_CSK
Thanks that is exactly where I thought it was but definately not there on my car so need to go searching for the cable/sensor as it must have dropped off. Current cars
Range Rover CSK
Discovery 3 HSE
Post #544365 18th Feb 2020 9:58pm
mpirie
Has the display only recently started showing -40?
That's the default temp when the temp sender has failed or the wiring is open circuit.
If it's missing then that would explain it, but it would have shown for a while.
Mike
Post #544386 19th Feb 2020 9:47am
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
I was under the impression that the sensor was in the drivers door mirror housing..??
Post #544387 19th Feb 2020 9:55am
Simon_CSK
Mike
I only got the car last wednesday and am starting to find and sort all the little things that need done. I would guess that it has been like that for a while. Current cars
Range Rover CSK
Discovery 3 HSE
Post #544392 19th Feb 2020 10:38am
mpirie
On my 2003 car, it was clipped to the rear of the front grille, so to take the grille off, you had to physically unmount the temp sender.
Is yours fitted with a standard grille? Could someone have replaced the grille and not remounted the sender?
If yours isn't there then look for the cable, it may be tucked away nearby.
Mike
Post #544465 19th Feb 2020 8:51pm
mpirie
I think that's only on 2010 cars and later.
Mike
Post #544466 19th Feb 2020 8:52pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, just bumping this old thread as my reported external temp is around 10 degrees down, i.e. on a normal day 12' I get the ice warning and 2' showing.
It's a 2012 Westminster, I see from this thread the temp sensor is apparently in the drivers door mirror, but I can't find it for looking. I can't find it in any other thread or the workshop manual either, but then again I'm not sure what I'm looking for.
Any guidance on how to access it and what it is I'm I'm looking for ?
Cheers, Andy Fuji White 2012 4.4 TDV8 Westmiinster
Post #690625 14th Apr 2024 8:05pm
Baltic Blue
Number 7 on the left hand mirror only.
Post #690626 14th Apr 2024 8:49pm
AndyRoo
That's great, many thanks, I was expecting it to look something like the original, tiny, no wonder I couldn't find it.
Post #690627 14th Apr 2024 8:55pm
